AndrewM Posted 7May, 2021 Report Share Posted 7May, 2021 Hi all, My 1999 996.1 accelerator pedal is starting to wobble from left to right to the extent where it is annoying. Has anyone fitted the Rennline gas pedal hinge? https://www.rennline.com/Rennline-Billet-Gas-Pedal-Hinge/productinfo/P76/ Are there better solutions out there? I am happy with the position of the pedals, so I don't feel I really need to look at replacing them all with https://www.rennline.com/Pedals-Fully-Adjustable/products/1127/ The Numeric pedals also looked interesting as they didn't require any drilling, https://store.numericracing.com/collections/986-996-pedals/products/performance-pedal-sets-986-996-pre-order , however seem overly expensive considering it is only the hinge that is bothering me. Also, I am not sure if the Numeric pedals are available in RHD. Grateful for thoughts if anyone has done this mod. Thanks, Andrew Quote Link to comment Share on other sites More sharing options...
Fishcop Posted 8May, 2021 Report Share Posted 8May, 2021 You'll need to check out whether your car is definitely a cable unit or FBW, and then clarify if the sets you're looking at are RHD compatible. I'd personally probably just go with OEM (but my car is stock everywhere). Quote Link to comment Share on other sites More sharing options...
