Dan Lemon Posted 17June, 2021 Report Share Posted 17June, 2021 Hi All, First time posting - I've owned my Porsche 944 (1984) for about a year. Unfortunately, the rear hatch has started sliding away from the trim piece above. I understand this is not an uncommon problem due to the hatch/strut design + poor hatch closing etiquette. The car is currently with the Porsche specialist here in Brisbane for a separate issue, but I am hoping to resolve this at the same time. I have discussed it with the mechanic and he has indicated that it is a somewhat fraught repair process. Has anyone had any experience with repairing this, or know of how to go about replacement? I'm quite the novice in dealing with older/classic cars, unsure how to progress. Had been hoping my first post would be a 'here's my working car', but not to be i suppose! Thank you Quote Link to comment Share on other sites More sharing options...
Rod C Posted 17June, 2021 Report Share Posted 17June, 2021 Have done this process in conjuntion with a friend who is an auto glass repairer. We seperated the frame from the glass with what looked like a piano wire slowly cutting through the old black adhesive. Cleaned and prepped all surfaces and then reapplied the frame to the glass using the black window adhesive. Used gaffer tape to hold tight and left it for 48 hours before installing as the struts can create movement. Stepo and brian in buddina 1 1 Quote Link to comment Share on other sites More sharing options...
brian in buddina Posted 17June, 2021 Report Share Posted 17June, 2021 @Rod C Was there any mechanical fasteners in there that needed replacing? I’m thinking clips or screws? How did the frame look after the repair? Quote Link to comment Share on other sites More sharing options...
Rod C Posted 17June, 2021 Report Share Posted 17June, 2021 10 hours ago, brian in buddina said: @Rod C Was there any mechanical fasteners in there that needed replacing? I’m thinking clips or screws? How did the frame look after the repair? From memory the only items ihad to replace were some of the small nut and bolts that secure the spoiler. Being in place for 35 years I had to sacrifice some to remove to three sections otherwise everything else was just cleaned up. Frame was fine and once in position the black adhesive cover all areas that were scraped clean and prepped. To remove nuts from spoiler I had to modify a flat screwdriver by removing a small portion in the middle. When you look at the nuts you will see what I mean. End of the screwdriver looked lioke a fork if that makes sense. You will need a fair amount of adhesive as you have to use it as a filler in some sections as did the factory. Could be wrong but it may have been eurothane that we used. brian in buddina and Stepo 1 1 Quote Link to comment Share on other sites More sharing options...
brian in buddina Posted 17June, 2021 Report Share Posted 17June, 2021 Thank you Rod. Do you know the brand & type adhesive you used? When I re sealed aluminium framed “windows” on a yacht a long time ago, I used a Sikkaflex product, poly… something (sulphide?). It said it permanently bonded to aluminium. Quote Link to comment Share on other sites More sharing options...
Dan Lemon Posted 17June, 2021 Author Report Share Posted 17June, 2021 20 hours ago, Rod C said: Have done this process in conjuntion with a friend who is an auto glass repairer. We seperated the frame from the glass with what looked like a piano wire slowly cutting through the old black adhesive. Cleaned and prepped all surfaces and then reapplied the frame to the glass using the black window adhesive. Used gaffer tape to hold tight and left it for 48 hours before installing as the struts can create movement. Thanks for your reply Rod. How long ago did you do the repair? I have been given the impression that perhaps refitting the glass may not be a long term solutions (will slide out again eventually). However, Finding and shipping another hatch also seems pretty tricky. Have you found any issues since repairing the glass? Quote Link to comment Share on other sites More sharing options...
Adam.B Posted 3September, 2022 Report Share Posted 3September, 2022 On 17/06/2021 at 11:15, Dan Lemon said: Hi All, First time posting - I've owned my Porsche 944 (1984) for about a year. Unfortunately, the rear hatch has started sliding away from the trim piece above. I understand this is not an uncommon problem due to the hatch/strut design + poor hatch closing etiquette. The car is currently with the Porsche specialist here in Brisbane for a separate issue, but I am hoping to resolve this at the same time. I have discussed it with the mechanic and he has indicated that it is a somewhat fraught repair process. Has anyone had any experience with repairing this, or know of how to go about replacement? I'm quite the novice in dealing with older/classic cars, unsure how to progress. Had been hoping my first post would be a 'here's my working car', but not to be i suppose! Thank you Any update? Just now, Adam.B said: Any update? I’m about to refurbish my rear hatch in the coming weeks Quote Link to comment Share on other sites More sharing options...
brian in buddina Posted 3September, 2022 Report Share Posted 3September, 2022 Adam Have you tried Rennlist for answers on the rear hatch? https://rennlist.com/forums/924-931-944-951-968-forum/1181736-944-rear-hatch-reseal-step-by-step-guide.html Adam.B 1 Quote Link to comment Share on other sites More sharing options...
Adam.B Posted 3September, 2022 Report Share Posted 3September, 2022 Yeah I have that saved and will be the basis on how I do it. Thank you brian in buddina 1 Quote Link to comment Share on other sites More sharing options...
