Jason E Posted 10October, 2021 Author Report Share Posted 10October, 2021 23 minutes ago, dan_189 said: I have a manual 98' 986 for sale if you're interested - Full books - Lots of factory options Also the main things I'd look for: - Wet rear carpet (behind the seats) means the drains have clogged and overflowed - if it's bad enough it can damage the alarm unit (which unintelligently sits under the passenger seat) - Roof alignment & function - Scan it with a proper scan tool (if the owner agrees) to see any codes - Check to see if it has any aftermarket alarms (have seen some really badly wired and eventually the unit fails) usually they have some sort of key fob if this is the case Could you PM some details & photos please? Where are you located? Cheers. Quote Link to comment Share on other sites More sharing options...
dan_189 Posted 10October, 2021 Report Share Posted 10October, 2021 Will do, I'm in Melbourne Quote Link to comment Share on other sites More sharing options...
Jason E Posted 10October, 2021 Author Report Share Posted 10October, 2021 26 minutes ago, dan_189 said: I have a manual 98' 986 for sale if you're interested - Full books - Lots of factory options Also the main things I'd look for: - Wet rear carpet (behind the seats) means the drains have clogged and overflowed - if it's bad enough it can damage the alarm unit (which unintelligently sits under the passenger seat) - Roof alignment & function - Scan it with a proper scan tool (if the owner agrees) to see any codes - Check to see if it has any aftermarket alarms (have seen some really badly wired and eventually the unit fails) usually they have some sort of key fob if this is the case Or my email if easier is jasoneacott71@hotmail.com Cheers Quote Link to comment Share on other sites More sharing options...
