brian in buddina Posted 17February, 2023 Report Posted 17February, 2023 In the process of rebuilding my 2.7 magnesium case. The preferred method of repairing the pulled head studs, common to this motor, is to machine in “case savers” inserts. Unfortunately Pelican parts has run out of stock and does not know when they will be re supplied. 24 required “Case Saver” for 10mm Stud - 14mm x 2.0 Outside, each x 25mm length, brand: Technovance When searching in Australia for the Technovance brand case savers I was only able to source Chinese brand copies of this product. Question1 Does anyone in Australia have any extra stock of the Technovance brand case savers? Question 2 Has anyone had any success with an alternative brand? In Wayne Dempsey book “How to rebuild and Modify Porsche 911 Engines 1965-1989” he goes into the reason why he prefers “case savers” and not to use “timecerts” due to the properties of the magnesium. Quote
tomo Posted 17February, 2023 Report Posted 17February, 2023 2 hours ago, brian in buddina said: In the process of rebuilding my 2.7 magnesium case. The preferred method of repairing the pulled head studs, common to this motor, is to machine in “case savers” inserts. Unfortunately Pelican parts has run out of stock and does not know when they will be re supplied. 24 required “Case Saver” for 10mm Stud - 14mm x 2.0 Outside, each x 25mm length, brand: Technovance When searching in Australia for the Technovance brand case savers I was only able to source Chinese brand copies of this product. Question1 Does anyone in Australia have any extra stock of the Technovance brand case savers? Question 2 Has anyone had any success with an alternative brand? In Wayne Dempsey book “How to rebuild and Modify Porsche 911 Engines 1965-1989” he goes into the reason why he prefers “case savers” and not to use “timecerts” due to the properties of the magnesium. Have checked out this mob? https://www.hfsindustrial.com/keysert brian in buddina 1 Quote
brian in buddina Posted 17February, 2023 Author Report Posted 17February, 2023 34 minutes ago, tomo said: Have checked out this mob? https://www.hfsindustrial.com/keysert Thanks Tomo had a look at there web site. There “keysert” was the closest but the catalogue doesn’t show the length. Will need to check that with them. tomo 1 Quote
Peter M Posted 18February, 2023 Report Posted 18February, 2023 Are the EMPI brand ones used on VW studs the right internal thread pitch? Case Savers 10mm I.D.X 14mm O.D. Set Of 8: AC1014012 | Heritage Parts Centre AU Quote
