Simonk Posted 20April, 2013 Report Share Posted 20April, 2013 Hi guys This weeks maintenance issue is a squeak coming from the front right. Only audible over large slow compression bumps. Turning doesn't seem to effect it. No squeak over small chattery bumps. If I stand on the door sill and bounce, it gets it squeaking badly. I took a look underneath and couldn't see anything obvious other than it looked like (excuse my lack of terminology) the joint at the end of the steering rod/arm thingy with the tow adjustment looked a bit greasy. Maybe silicon spray by the previous owner to cover the squeak? Anyway, once I lowered the car off the jack, the squeak had gone. I haven't taken it for a drive yet but bouncing on the door sill doesn't produce the squeak any more. Any thoughts? Link to comment Share on other sites More sharing options...
tazzieman Posted 20April, 2013 Report Share Posted 20April, 2013 A arm (control arm) bushings , have they been done? Link to comment Share on other sites More sharing options...
jnr356 Posted 20April, 2013 Report Share Posted 20April, 2013 it will be the torsion bar end cap needs some grease and sometimes building the wearing edge up with a bead of weld Link to comment Share on other sites More sharing options...
tazzieman Posted 21April, 2013 Report Share Posted 21April, 2013 it will be the torsion bar end cap needs some grease and sometimes building the wearing edge up with a bead of weld Staving off the inevitable A arms are not that hard to fix, nor expensive if you don't mind getting down and leetle bit dirty. Link to comment Share on other sites More sharing options...
