SteveF Posted 12April, 2014 Report Share Posted 12April, 2014 I am going to have a crack at straightening and recovering my door pockets because they rub against the door rubber when closing the door, to the point where the drivers door rubber has split. I suspect that eventually the door card will eventually need recovering but this is the first step. One little project at a time. I have removed the passenger side pocket and old vinyl with a heat gun (my wife's hair dryer when she wasn't looking). I heated up the area I want to straighten and clamped it to some timber. I will leave that overnight and see if that works. If all good I will do same in other areas. Before I recover it what would you recommend I give it a clean with? Methylated spirits? I think I will recover it in a similar black vinyl to keep the same look. Any suggestions on where to purchase this? An auto trimmer or somewhere like Bunnings? I imagine I will need some special glue. Any suggestions? Anything else? Thank you Link to comment Share on other sites More sharing options...
clutch-monkey Posted 12April, 2014 Report Share Posted 12April, 2014 upholstery glue should do the trick. wax and grease remover is what i would use to clean it off first. if you run into trouble don't fret.. i've got a pair of door pockets sitting here doing nothing haha. Link to comment Share on other sites More sharing options...
Russ Posted 12April, 2014 Report Share Posted 12April, 2014 I'm certain one of the guys on here re-did there's already with pictures, by wetting the cardboard first and then drying it in a jig. I cant seem to find the thread tho Link to comment Share on other sites More sharing options...
SteveF Posted 12April, 2014 Author Report Share Posted 12April, 2014 Thanks Clutch-monkey for the information. The door pockets are in pretty good nick but if I bugger it up I may need to speak to you about your spares. Hey Russ, I found the thread. Thanks for letting me know. I just to need to source some vinyl now. Steve Link to comment Share on other sites More sharing options...
SteveF Posted 3May, 2014 Author Report Share Posted 3May, 2014 In case anyone is interested I was given a contact for an auto trimmer from Bob Whyms. He recommended contacting Lincoln at Prestiage Link in Botany. I spoke with Lincoln and he was very helpful with costings but I can't comment on the work as I haven't used them as yet. Will probably get them to do my headliner. Bob mentioned that Lincoln has done a fair bit of work for them in the past. Link to comment Share on other sites More sharing options...
