Russ Posted 17April, 2014 Report Share Posted 17April, 2014 argh, so I'm in the process of doing my plugs - but I've got a few questions: They're gapped at 0.8mm, the handbook with the car says to gap them at 0.7mm - Should I bother? does anyone else bother? I assume it's not going to make a huge difference (I'm still running original CDI for the time being) Does anyone torque their spark plugs into the head? I'm always worried about stripping threads on air cooled engines (I've been doing the old 'get it tight and go a quarter turn to crush the washer') What combination of sockets do people use? I've got a Repco set and use a universal joint, with the 90 degree as an extra bit of length and then the captive spark plug socket - I'm having a real prick of a time with cylinder #1 - it's like there's a lip on there the combination is catching on - I read in 101 projects there is a craftsman branded spark plug socket with a uni joint in built (but it's been impossible to find here) - maybe a shorter short extension is the go (the standard one I can't get in there) Thanks in advance! I got my coil changed tonight and 3 of the plugs done before I lost interest (which coincided with dinner being ready and some good TV being on) Link to comment Share on other sites More sharing options...
tk111 Posted 17April, 2014 Report Share Posted 17April, 2014 I did the plugs recently and found this tool extremely easy to use, much better then trying to mess about with socket sets and extensions. I just used an allen key once I had the tool in place. Easy job! Link to comment Share on other sites More sharing options...
Russ Posted 17April, 2014 Author Report Share Posted 17April, 2014 Dang I forgot about that tool! I'll check my toolkit. Thanks Link to comment Share on other sites More sharing options...
Russ Posted 17April, 2014 Author Report Share Posted 17April, 2014 Damn I'm missing that tool! Anyone in Brisbane have one I can borrow tomorrow? I have the Allen key for it though Link to comment Share on other sites More sharing options...
Caledonian Posted 17April, 2014 Report Share Posted 17April, 2014 I don't have that spark plug tool either, I used a 3/8 wobble drive extention with no problems (your welcome to borrow )and yes i did torque them but I'm not changing plugs every day and as you mentioned they can strip with a little too much enthusiasm. Plug gap,hmmmm not sure if that would make much difference, what were the old ones gapped at? Link to comment Share on other sites More sharing options...
Russ Posted 17April, 2014 Author Report Share Posted 17April, 2014 They were 0.8 too. Thanks mike, where are you? I'vve got a hose for you too Link to comment Share on other sites More sharing options...
Caledonian Posted 17April, 2014 Report Share Posted 17April, 2014 PM sent Link to comment Share on other sites More sharing options...
911oclock Posted 17April, 2014 Report Share Posted 17April, 2014 I've got one Russ Link to comment Share on other sites More sharing options...
Russ Posted 17April, 2014 Author Report Share Posted 17April, 2014 Are you around tomorrow Andrew and mind if I borrow it? Link to comment Share on other sites More sharing options...
911oclock Posted 17April, 2014 Report Share Posted 17April, 2014 I'm home tomorrow. You're welcome to use my cave if you want to as well, I don't mind watching you work... Link to comment Share on other sites More sharing options...
Russ Posted 17April, 2014 Author Report Share Posted 17April, 2014 Lol, can I come grab the tool? I'm sort of half way through the job Link to comment Share on other sites More sharing options...
911oclock Posted 17April, 2014 Report Share Posted 17April, 2014 Sure that's no problem. Link to comment Share on other sites More sharing options...
Russ Posted 18April, 2014 Author Report Share Posted 18April, 2014 amazing difference, more power and better response! idles properly too - THE BEST BIT! my 4900RPM miss is gone! and I found the washer I dropped into the engine bay when I was taking the decklid grille off! the old leads disintegrated as I took them off (and I'd been told by a few different people they looked fine, and I thought so too) there was some slight confusion about the firing order as I discovered the cap I'd ordered had a crack in it but thanks to Caledonian's SMS picture help I got them in the right order. thanks to tk111 for the suggestion of the tool to use, and 911oclock and Caledonian for the lend of tools today (I must get one of those spark plug tools - they are the best thing ever for changing plugs they make a difficult job easy) tomorrow I've got a few heater hoses to change and the airbox straps to do too - they're currently all soaking in hot water to soften them up so they'll fit on Link to comment Share on other sites More sharing options...
Caledonian Posted 18April, 2014 Report Share Posted 18April, 2014 Good to hear! Link to comment Share on other sites More sharing options...
