Strange compression / leak down test results - help
550Spyder
Team
Looking at acquiring a 3.2 carrera engine running high compression pistons and twin plug head. New motor with 5000 km.
Leak down test perfect at 2-3%.
Compression above 200 in all cyclinders. But one cylinder bank is 10% higher compression than the other. Cam timing checked and ok.
Going to re-perform the test tomorrow from dead cold and from the bottom plug holes (in case one bank not torqued up propperly).
How worried should I be if one bank is so different from the other?
might be oil or something in it. When was it tested, hot or cold?
Need to do compression while throttle is open and while engine is hot.
Not sure uncle. But was performed by a recognised Porsche specialist so I am confident they know how to perform the test.
Just don't understand the results.
