John82SC Posted 13August, 2014 Report Share Posted 13August, 2014 Hi all, need to replace all the discs. Any wisdom out there on replacements? planning on staying with the stock setup, mainly to keep costs down. Although, haven't entirely ruled out an upgrade. Any advise appreciated. J Link to comment Share on other sites More sharing options...
Stew F Posted 13August, 2014 Report Share Posted 13August, 2014 Haven't had to put new one on my 911, but I bought some DBA slotted rotors a few years ago for my 5.7L Adventra. They seemed to make a moderate difference to the stopping capability, but they appeared to stay flat for longer, and a bit less fade when towing my boat down long hills. Used them on other cars as well and have always had good results. When I eventually need some my my SC I will probably get the DBA ones. Link to comment Share on other sites More sharing options...
Russ Posted 13August, 2014 Report Share Posted 13August, 2014 I'm just going to replace with ATE or Mayle Rotors/Pads when required in line with the standard stuff. I wonder what cost of DBA vs Stock is though Link to comment Share on other sites More sharing options...
tazzieman Posted 13August, 2014 Report Share Posted 13August, 2014 Standard SC brakes are accepted to be more than adequate . Unless you are a dedicated racer. Cross drilled "look cool" but I did extensive research and the consensus of knowledgeable opinion was there no significant benefit over slotted for street cars.I have replaced all discs with solid and have no complaints ; I drive in the wet and I hit the track , though not 1 on 1. Few sane family-oriented people do! My 928 just got grooved discs , but I ordered solid. Ah well. Pads? define your use and choose accordingly. I want mine to work from cold as I live on a steep hill. And I detest brake dust. Front pads for my 928 "supercar" cost $79. It stops on a dime. I used standard brake hoses on the 911. Stainless on the 944 and 928 , and I think they give a slightly crisper pad feel, but it's probably placebo. Nobody ever sees them but maybe they withstand the gravel on my local roads a bit better? Link to comment Share on other sites More sharing options...
John82SC Posted 13August, 2014 Author Report Share Posted 13August, 2014 Thanks guys, gotta love a response that includes "I did extensive research". I've virtually no experience of actually driving my car as I bought it broken, apart from a sneaky quick spin, running on 5 pots and, ironically, with 3 of the 4 brakes binding.. so this is just the info I'm after. sounds like stock setup should be fine then, maybe with stainless hoses so it'll 'feel' better. Cheers Link to comment Share on other sites More sharing options...
tazzieman Posted 13August, 2014 Report Share Posted 13August, 2014 If the brakes are binding you need to check and reseal the pistons. Is it a UK car? Link to comment Share on other sites More sharing options...
John82SC Posted 13August, 2014 Author Report Share Posted 13August, 2014 Will be refurbishing the entire system, overhauling calipers and m/cyl. Japanese import, but L/H drive. (r.o.w.) Link to comment Share on other sites More sharing options...
tazzieman Posted 13August, 2014 Report Share Posted 13August, 2014 Will be refurbishing the entire system, overhauling calipers and m/cyl. Japanese import, but L/H drive. (r.o.w.) The best sort of sc Link to comment Share on other sites More sharing options...
911oclock Posted 13August, 2014 Report Share Posted 13August, 2014 Don't know if DBA make discs for an sc.....they don't for my Carrera. After plenty of home work looking at importing from the US/UK it ended up being cheaper and more convenient to source in Aus (Just James). Link to comment Share on other sites More sharing options...
