Anyone have 952 AFM I could borrow ?
cyberpunky
Well I all out of ideas as to what is wrong with my car. So far I have changed Leads, Rotor, Dist cap, TPS, DME, DME temp sensor, Speed and Ref sensor harness, and plugs. I also did a refurb on my AFM She is still running like a pig. I would love to swap out the AFM to see if that is causing it, so if anyone has one I could borrow that would be greatly appreciated
cheers
Bruce
I really wanted an M tune but just when I decided to get one Josh stopped supply and looks like it will be a while before they are available again :(
Check with Lart. He usually has one every now and then.
Do you have a data logger? can't remember if you had bought one or not. But i do suggest you get one. Mine has helped me rule out a few problems.
I log
RPM
AFR - WBo2
TPS
MAF
MAP
If you can at least log rpm tps and your AFM. you can rule out the afm by looking at the voltage signal next to the TPS & RPM signals.
