Stew F Posted 22October, 2014 Report Share Posted 22October, 2014 I need to get a new one of the hoses in the attached picture. The parts list shows 2 of them (both item 8), then a heap of other numbers. How do I work out which is the correct one, and what do all the other numbers mean? http:// http:// Secondly, my engine compartment light isn't working. Is there a separate fuse for this little sucker? I found it in the wiring diagram, and everything else that is supposed to come off this circuit works fine. Any ideas? It's quite a neat design though. Thanks. Link to comment Share on other sites More sharing options...
Stew F Posted 22October, 2014 Author Report Share Posted 22October, 2014 Update on the light. I removed it from the car and tested it. The light unit works fine. Where do the wires go after they come off the hinge assembly? Almost looks like they go toward the front of the car somewhere (on the LHS). Link to comment Share on other sites More sharing options...
Peter M Posted 22October, 2014 Report Share Posted 22October, 2014 Stew,The "80-" means for vehicles 1980 onwards so assuming you are buying for your 1982 SC, the 930 211 031 00 is your part number. Also doing a check on Pelican Parts sometimes helps: http://www.pelicanparts.com/cgi-bin/ksearch/pel_search_2014.cgi?SUPERCAT_FLAG=Y&make=POR&Context_make=&please_wait=N&LastVisited_input=0798&Previous_Section=&forumid=&threadid=&command=DWsearch&description=93021103100&I1.x=13&I1.y=4As for the engine compartment light, have you tested it with the headlights on? (I have a vague recollection that there is a connection!) Link to comment Share on other sites More sharing options...
Stew F Posted 22October, 2014 Author Report Share Posted 22October, 2014 Thanks Peter, I'll do that check with the lights on. I have a suspicion you might be right because in the book of dark magic (wiring schematics) it shows it coming off the side marker circuit, which obviously would only work with the light switch on. I haven't checked with PC - Adelaide re the hose. Does anyone know if it is still available? Cheers. Link to comment Share on other sites More sharing options...
Stew F Posted 22October, 2014 Author Report Share Posted 22October, 2014 Thanks Peter. Link to comment Share on other sites More sharing options...
Peter M Posted 22October, 2014 Report Share Posted 22October, 2014 LOL!You're very welcome Stew! Link to comment Share on other sites More sharing options...
Russ Posted 22October, 2014 Report Share Posted 22October, 2014 http://www.fcpeuro.com/products/porsche-hvac-blower-fan-hose-911-25343003001 I got one of these, it was 'interesting' to fit (had to bend it into shape) but it's good now it's on! Link to comment Share on other sites More sharing options...
Stew F Posted 22October, 2014 Author Report Share Posted 22October, 2014 Thanks Russ. I've read on Pelican just now that some of them are a bit fiddly to fit, but once they're on they are fine. Cheers all. Link to comment Share on other sites More sharing options...
