Pusche_944 Posted 2December, 2014 Report Share Posted 2December, 2014 Hey guys, I am keen to hear from anyone that may have working speed and reference sensors kicking around that they no longer need. PM me if you do and what you think they are worth. Cheers Link to comment Share on other sites More sharing options...
Pauly Posted 2December, 2014 Report Share Posted 2December, 2014 Go buy new ones mate. Not worth the issues with second hand ones. http://www.pelicanparts.com/catalog/SuperCat/1014/POR_1014_ELSENS_pg1.htm Bosch is the factory part. FAE is what BMW uses. I have the FAE on my car. Link to comment Share on other sites More sharing options...
Pusche_944 Posted 2December, 2014 Author Report Share Posted 2December, 2014 Thanks Pauly...I was looking at the second hand path as I'm not 100% sure if this is my issue or not. Given the link - the FAE option looks pretty appealing. Thanks again Link to comment Share on other sites More sharing options...
911oclock Posted 2December, 2014 Report Share Posted 2December, 2014 If the rubber insulation on yours is brittle and crumbling away it's not a bad idea to change them anyway. Link to comment Share on other sites More sharing options...
Pauly Posted 2December, 2014 Report Share Posted 2December, 2014 What exactly is your issue? 911oclock is correct, the rubber goes brittle and so does the wire insulation which causes issues. Link to comment Share on other sites More sharing options...
cyberpunky Posted 2December, 2014 Report Share Posted 2December, 2014 and it's doubtful anyone keeps suspect sensors once they are removed, even if they are not culprit. I sure wouldn't even consider fitting anything but new ones. I'm curious too. what issue are you chasing ? Link to comment Share on other sites More sharing options...
Pauly Posted 2December, 2014 Report Share Posted 2December, 2014 As bruce said. I cut the lead of one and glued a washer at the end of it to use it to gap it from the flywheel. Link to comment Share on other sites More sharing options...
