GUT Posted 25June, 2015 Report Share Posted 25June, 2015 Any ideas how to get this hideous thing off?Being so shiny and smooth, I just can't get enough grip. Link to comment Share on other sites More sharing options...
Peter M Posted 25June, 2015 Report Share Posted 25June, 2015 If it's a push on fit like the standard knob, push down the leather boot so you can get something underneath - a chisel, piece of wood or snug fitting open end spanner - and drive if off with a hammer.When I swapped my shifter for a Wevo classic I couldn't get the original knob off the standard lever with it still in the car and had to remove the lever and fix in a vyce to be able to shift it.Alternatively, if you don't want to reuse the knob, a coupla vertical slits with an angle grinder will make if fall off! Link to comment Share on other sites More sharing options...
vl gra Posted 25June, 2015 Report Share Posted 25June, 2015 Looks like the collar under the knob unwinds, then there will be allen key bolts retaining it to the shaft. Link to comment Share on other sites More sharing options...
turboT Posted 25June, 2015 Report Share Posted 25June, 2015 try your left hand. Its like a mechanic is helping out Link to comment Share on other sites More sharing options...
GUT Posted 25June, 2015 Author Report Share Posted 25June, 2015 Thanks guys.It's really quite easy once you know how.Very satisfied now.Unscrewed the collar, loosened three little screws and off it came.MUCH better now Link to comment Share on other sites More sharing options...
vl gra Posted 26June, 2015 Report Share Posted 26June, 2015 No problems glad I could help out. Link to comment Share on other sites More sharing options...
