HH1 Posted 11August, 2015 Report Share Posted 11August, 2015 Hi Guys,My passenger side seat is stuck in the full back position and won't move forward. It moves back and up and down and every other position works but the motor simply doesn't activate when the front button is pressed. How do remedy this? Sohan Link to comment Share on other sites More sharing options...
KGB Posted 11August, 2015 Report Share Posted 11August, 2015 Do a search on Rennlist as it's quite a common fault. Link to comment Share on other sites More sharing options...
T-Man Posted 11August, 2015 Report Share Posted 11August, 2015 Link to comment Share on other sites More sharing options...
HH1 Posted 11August, 2015 Author Report Share Posted 11August, 2015 I've unscrew the switch from the bracket and can't see how to remove the switch from the assembly. Also the power cable is really short and I'm only able to pull the switch out about 2cm and i can't see how to unclip the switch. Link to comment Share on other sites More sharing options...
HH1 Posted 12August, 2015 Author Report Share Posted 12August, 2015 Update. Did the steps as shown by Pauly, but had to remove the seat and turn it on its head to access the switch. WD40'd it, glued the ball bearings onto the springs. Closed it all back up. Installed seat and voila - nothing! All other functions work except forward. Any other suggestions!Sohan Link to comment Share on other sites More sharing options...
