thesnowdrift Posted 22July, 2011 Report Share Posted 22July, 2011 hi guys i currently have the original standard torsion bars, does anyone know if the turbo bars of my models were bigger and any stiffer? is this a feasible swap, i don't want crazy upgrade to hollow race bars just something a little stiffer... can anyone recommend an option? thanks Pete Link to comment Share on other sites More sharing options...
Guest vas930 Posted 22July, 2011 Report Share Posted 22July, 2011 Hi Pete. Yes the turbo bars are bigger,mainly due to the weight of the engine. 21mm front and 26mm rear may be a good place to start, if you want to change. Do you track your car? If yes this may be an advantage. If not the standard setup is more than adequate. My dads 74 Carrera was very succcessful on track with the stock setup. Hope some of the Carrera boys jump in on this and give an opinion. Talk to the experts also. http://www.rennsportsystems.com/1-e.html This is a good start. Hope this helps and let us know how you go. Good luck. Vas Link to comment Share on other sites More sharing options...
thesnowdrift Posted 22July, 2011 Author Report Share Posted 22July, 2011 Hi Pete. Yes the turbo bars are bigger,mainly due to the weight of the engine. 21mm front and 26mm rear may be a good place to start, if you want to change. Do you track your car? If yes this may be an advantage. If not the standard setup is more than adequate. My dads 74 Carrera was very succcessful on track with the stock setup. Hope some of the Carrera boys jump in on this and give an opinion. Talk to the experts also. http://www.rennsportsystems.com/1-e.html This is a good start. Hope this helps and let us know how you go. Good luck. Vas Hi Vas Thanks for the input... I have all new poly bushes, carrera sway bars, turbo tie rodends... Was intended for a little occasional track work... They are 35 yr old so may be time for new ones... Hope some more guys have some input... Cheers Pete Cheers Link to comment Share on other sites More sharing options...
Guest vas930 Posted 22July, 2011 Report Share Posted 22July, 2011 Sounds good Pete. 21mm front and 26mm seems to be the go from what you say you want. Any bigger and the car may become to hard for street use. Jnr356 may have some good advice also. What does your Porsche mech think? Link to comment Share on other sites More sharing options...
jnr356 Posted 22July, 2011 Report Share Posted 22July, 2011 what vas said got some adjustable koni's in there yet? Link to comment Share on other sites More sharing options...
thesnowdrift Posted 23July, 2011 Author Report Share Posted 23July, 2011 cheers guys yes jnr i got the koni's in there...even done engine mounts when i done bushes... i am looking for a new mechanic in WA i have had conflicting stories... one said yes and the splines will be different so will have to reset ride height, wheel alignment and corner balance again... the other just said no and if i did splines are the same only problem would be is that it would weaken the body after a couple of years... Pete Link to comment Share on other sites More sharing options...
jnr356 Posted 23July, 2011 Report Share Posted 23July, 2011 yes you will have to reset ride heights and redo alignment,wouldn't bother with corner weights but the torsion bars need to be set 100% correctly as for the weakening the body...one word.....WANKER,stay away from this guy .he either doesn't know what he's talking about or doesn't want to do the job thought about a trip to victoria? there's a few places i would trust here probably need your car for a day or two Link to comment Share on other sites More sharing options...
thesnowdrift Posted 23July, 2011 Author Report Share Posted 23July, 2011 yes you will have to reset ride heights and redo alignment,wouldn't bother with corner weights but the torsion bars need to be set 100% correctly as for the weakening the body...one word.....WANKER,stay away from this guy .he either doesn't know what he's talking about or doesn't want to do the job thought about a trip to victoria? there's a few places i would trust here probably need your car for a day or two Cheers jnr I was thinking same thing...WANKER, but for someone who has been in the business for 30 yrs you would think he knows a thing or two... I am in WA with car now so a trip to Vic is a bit tough, will just keep looking here... You seem to be full of knowledge, what would you suggest for a steering rack with a little free play...Rebuild? Thanks Pete Link to comment Share on other sites More sharing options...
jnr356 Posted 23July, 2011 Report Share Posted 23July, 2011 i'd reckon the flange on the pinion is probably a little loose,pain in the arse job ,only need about a half a turn to tighten it up. try that 1st ,those racks are fairly bulletproof Link to comment Share on other sites More sharing options...
thesnowdrift Posted 23July, 2011 Author Report Share Posted 23July, 2011 i'd reckon the flange on the pinion is probably a little loose,pain in the arse job ,only need about a half a turn to tighten it up. try that 1st ,those racks are fairly bulletproof already done, no joy... it was suggested i try a second hand unit, think i will just go rebuild... cheers jnr Pete Link to comment Share on other sites More sharing options...
jnr356 Posted 23July, 2011 Report Share Posted 23July, 2011 mmm..strange Link to comment Share on other sites More sharing options...
thesnowdrift Posted 23July, 2011 Author Report Share Posted 23July, 2011 mmm..strange well i was told it was by an Adelaide Porsche expert... or was that just more bullshit... cheers jnr, i will look in to it Pete Link to comment Share on other sites More sharing options...
jnr356 Posted 23July, 2011 Report Share Posted 23July, 2011 it's just in 30 years i don't think i've seen a shagged out rack post 1974? ish in a 911 had quite a few with that loose pinion flange,which is fairly indiscriminate (ie.hard to pick) Link to comment Share on other sites More sharing options...
thesnowdrift Posted 24July, 2011 Author Report Share Posted 24July, 2011 it's just in 30 years i don't think i've seen a shagged out rack post 1974? ish in a 911 had quite a few with that loose pinion flange,which is fairly indiscriminate (ie.hard to pick) cheers mate... i will get another opinion to support your theory, i have heard elsewhere that they are indestructable... if thats all it is i am going to be mighty pissed paying 4 hours labour if it is that and wasn't done... also just found today when adjusting brake light switch that master cylinder that was apparently ok with previous mentioned expert appears to be spewing fluid into the pedal box... thanks again jnr i am now looking at the 21mm and 26mm torsion bars with rennsport Pete Link to comment Share on other sites More sharing options...
Guest vas930 Posted 25July, 2011 Report Share Posted 25July, 2011 Another good company for torsion bars. http://www.elephantracing.com/ Let us know how you go with it. Link to comment Share on other sites More sharing options...
thesnowdrift Posted 28July, 2011 Author Report Share Posted 28July, 2011 Hi Guys Thanks for your advice... I am looking at going with hollow bars 21mm front and 26mm rear from Pelican...any thoughts? Also thinking i might up the brake master cylinder too, since mine is the original 17mm unit and use the Pelican 19mm unit Pete Link to comment Share on other sites More sharing options...
Guest vas930 Posted 29July, 2011 Report Share Posted 29July, 2011 Sounds great Pete. Whats the weight saving over the solid bars? Link to comment Share on other sites More sharing options...
thesnowdrift Posted 30July, 2011 Author Report Share Posted 30July, 2011 Sounds great Pete. Whats the weight saving over the solid bars? according to Pelican it was something like 30% in the front and about 40% rear... from what i am reading on their site they are weltmeister bars... i hope they are a good investment Link to comment Share on other sites More sharing options...
Wobbly Posted 1August, 2011 Report Share Posted 1August, 2011 Sorry to butt in ... jnr, where would you recommend in vic to go talk suspension? I need to do mine at some point, but I also need to find someone who knows what they are doing who can weld in some adjustable rear camber boxes once I get them off back order from elephant in the states... Link to comment Share on other sites More sharing options...
PeterP Posted 4August, 2011 Report Share Posted 4August, 2011 Sorry to butt in ... jnr, where would you recommend in vic to go talk suspension? I need to do mine at some point, but I also need to find someone who knows what they are doing who can weld in some adjustable rear camber boxes once I get them off back order from elephant in the states... Hi Wobbly, Don't know where you are located, but maybe you should have a chat with Mike at Spyder Automobiles in Warragul.Mike has a long history with Porsches, and is great at expalining options etc. At the moment I have my 78 SC with him and He is upgrading to Turbo Tie rods, Koni Sports, and 21 and 29mm Sander Engineering (U.S) tubular torsion bars, plus a brake upgrade. Not cheap, but I believe the results will be worth it!! Am I excited? You bet!! regards Peter Link to comment Share on other sites More sharing options...
Wobbly Posted 5August, 2011 Report Share Posted 5August, 2011 Thanks Peter - bit of a hike for me, I'm in Beaumaris Anyone closer around the south east that anyone can recommend? Link to comment Share on other sites More sharing options...
Guest vas930 Posted 5August, 2011 Report Share Posted 5August, 2011 Hey Wobbly, talk to Loui at Motion Automotive. Has been woking on Porsche only for a long time. He is in Sth Melbourne. ph 96450022 Let us know how it goes. Good luck. Link to comment Share on other sites More sharing options...
thesnowdrift Posted 10August, 2011 Author Report Share Posted 10August, 2011 stealing my post back 21 and 26 bars from Weltmeister are on the way, along with a 23mm Master Cylinder... Link to comment Share on other sites More sharing options...
PeterP Posted 16August, 2011 Report Share Posted 16August, 2011 stealing my post back 21 and 26 bars from Weltmeister are on the way, along with a 23mm Master Cylinder... Folks, For what its worth, I got the car back on the weekend, and the transformation is brilliant. It handles brilliantly, and just performs so much better. All the best wit your upgrades; I think you'll be amazed at the difference. regards Peter Link to comment Share on other sites More sharing options...
Guest vas930 Posted 17August, 2011 Report Share Posted 17August, 2011 Well done Peter, glad your happy. Hows the comfort factor? Link to comment Share on other sites More sharing options...
