Troy997.1 Posted 12March, 2016 Report Share Posted 12March, 2016 What's the best tyre pressures for normal driving and then track days for a 997 Link to comment Share on other sites More sharing options...
Mike737 Posted 12March, 2016 Report Share Posted 12March, 2016 Depends on what tyres you're running.Porsche has recommended pressures in their owners manual which are perfect for daily use.For track you generally start off with lower pressures although your initial wear rate will be higher but will stop them from becoming over inflated.If you're running an R type tyre you might be able to contact a specialist supplier who represents that brand and they'll be able to help you out.Otherwise you could buy the gear and do a few laps and find out your temps and adjust accordingly Link to comment Share on other sites More sharing options...
911 Snake Posted 14March, 2016 Report Share Posted 14March, 2016 I go by the book for my 997 Carrera for daily use which run the 19inch 'S' wheelsmichelin pilot supersports33psi front 235/35 R1939psi rear 295/30 R19 Link to comment Share on other sites More sharing options...
