Merv Posted 16May, 2016 Report Share Posted 16May, 2016 My B T6 has its original carpets in square-weave "Oatmeal". The carpet is old but clean and quite serviceable. I do not want to 'restore' the car. However, the two side panels near the door entry points are threadbare and if I could just buy those pieces, I would be interested. Are there places where sections can be purchased? Or do you buy some carpet and have it trimmed to suit? Link to comment Share on other sites More sharing options...
Aircooled Junkie Posted 18May, 2016 Report Share Posted 18May, 2016 You will need to buy carpet and have it made up and fitted individually to your car. Garry Blackman ( motor trimmer in Richmond, Melbourne ) is contiually retrimming 356s and can supply correct factory oatmeal box weave carpet. You actually need a few metres ( he will know ) since each side must travel full length of thresthold and finish around base of rear squabs.. Link to comment Share on other sites More sharing options...
Merv Posted 19May, 2016 Author Report Share Posted 19May, 2016 I have written to Garry, but no reply as yet. I did find that Prostitch http://www.prostitch.com.au in Sydney has the correct German carpet and colour. They are sending a sample to check the match. I have dealt with them before and they normally have the authentic materials. When I pulled all my original carpets out for cleaning, I seem to recall that mine do not wrap around and under the rear squabs? They extended from the corner in the rear to the front kick board section. Link to comment Share on other sites More sharing options...
rafikdous Posted 24May, 2016 Report Share Posted 24May, 2016 Merv, contact Oggie from Autos International in the USA. I dealt with them many times and happy every time with their service. He will supply whatever pieces you are after Link to comment Share on other sites More sharing options...
Merv Posted 25May, 2016 Author Report Share Posted 25May, 2016 Thanks Rafik. I have a sample of the correct weave Oatmeal from Prostitch and will see how that matches. If all good then I will have it trimmed locally using the original as a base. Link to comment Share on other sites More sharing options...
michel Posted 26May, 2016 Report Share Posted 26May, 2016 Merv there is also Televiski in Mlb and also Le Mans in NZ Link to comment Share on other sites More sharing options...
Merv Posted 2June, 2016 Author Report Share Posted 2June, 2016 Thanks Michel. I have some coming from Prostitch. Link to comment Share on other sites More sharing options...
