Aussieboxy Posted 30June, 2016 Report Share Posted 30June, 2016 I recently replace the brake booster on my 00 Boxster & now I can't bleed the rear brakes & the front brakes locked when taking it for a test drive.Any suggestions? Link to comment Share on other sites More sharing options...
tazzieman Posted 30June, 2016 Report Share Posted 30June, 2016 Not a Boxster owner , but check para 2 of this article http://www.pelicanparts.com/techarticles/Boxster_Tech/48-BRAKES-Bleeding_Brakes/48-BRAKES-Bleeding_Brakes.htm Link to comment Share on other sites More sharing options...
Aussieboxy Posted 2July, 2016 Author Report Share Posted 2July, 2016 Thanks Tazzie,Mine doesn't have PSM. Link to comment Share on other sites More sharing options...
tazzieman Posted 2July, 2016 Report Share Posted 2July, 2016 Thanks Tazzie,Mine doesn't have PSM.Probbaly quickest to ask on Rennlist , as not a lot of Bxster DIY on PFA Link to comment Share on other sites More sharing options...
Stew F Posted 2July, 2016 Report Share Posted 2July, 2016 When you say you can't bleed the rears do you mean you can't get all of the air out? Link to comment Share on other sites More sharing options...
Aussieboxy Posted 6July, 2016 Author Report Share Posted 6July, 2016 Nothing comes out of the rear brakes when the nipple is opened. Open all niplles & the brake pedal is still hard Link to comment Share on other sites More sharing options...
ANF Posted 6July, 2016 Report Share Posted 6July, 2016 Is it the correct brake booster for your Boxster?What was the issue with the old one? If it was still functioning, take the new one off and put the old one back on and if it works then could be wrong booster or faulty? Also to make sure all is installed correctly. Link to comment Share on other sites More sharing options...
