Funbug Posted 8January, 2017 Report Share Posted 8January, 2017 im in the process of replacing my evaporator on my 993. I need ideas or help with ccu removal - it doesn't want to budge!!! I'm on the Sunshine Coast. Thanks Link to comment Share on other sites More sharing options...
Peter M Posted 8January, 2017 Report Share Posted 8January, 2017 You're using the wire keys through the front panel to disengage the tabs?They look like this:http://www.ebay.com.au/itm/Radio-REMOVAL-Tool-Key-Set-Car-Audio-Stereo-CD-Release-Auto-Ford-Holden-DIN-Sing-/322089432382?hash=item4afe06b53e:g:tEIAAOSwsN9XAIQ1Or are you talking about disconnecting the rear electrical plug?Are you following one of the useful threads on here or Rennlist to do the replacement?Have you said goodbye to your loved ones for 10hours? Link to comment Share on other sites More sharing options...
Funbug Posted 8January, 2017 Author Report Share Posted 8January, 2017 I'm using the wire keys - even tried the Toolpro radio removal multi tool Link to comment Share on other sites More sharing options...
Peter M Posted 8January, 2017 Report Share Posted 8January, 2017 Sometimes the keys will go in to far and will actual jam the locks so maybe try at different penetrations.Are you able to feel the back of the unit while you do this so you might be able to feel when each side unlocks as you wiggle the key. Link to comment Share on other sites More sharing options...
Funbug Posted 8January, 2017 Author Report Share Posted 8January, 2017 Success at last!!! Struggled for 2 hours without any luck. Got a 12 piece car audio and interior removal kit from Jaycar (no relationship) and the tool went in the correct distance and the ccu was out in less than a minute. Link to comment Share on other sites More sharing options...
Peter M Posted 8January, 2017 Report Share Posted 8January, 2017 Funbags,I found this useful:http://www.pcarworkshop.com/index.php/993_-_A/C_Evaporator_ReplaceSince there were minor variations across the model year, I would suggest taking photos of the air flap actuator arm locations before you actually disassemble the air box to avoid some later headscratching.Also, to save money and time I found the only other useful thing I've learnt is that the standard receiver dryer for 993/964's and I guess from the part number, 944's as well (Part No. 944-573-143-01) is the same used in Toyota Camry's 1993 to 2002 and many other cars.I've found Autofrost at Milperra (02 9774 4133) good to deal with the two I've bought to date and their part number for a generic one is RD 7001. Cost $17.50 Link to comment Share on other sites More sharing options...
Funbug Posted 8January, 2017 Author Report Share Posted 8January, 2017 Peter thanks for your advice, it's been very helpful ?? Link to comment Share on other sites More sharing options...
TINGY Posted 8January, 2017 Report Share Posted 8January, 2017 Ask Pete about oil............go on I dare you. Link to comment Share on other sites More sharing options...
Funbug Posted 8January, 2017 Author Report Share Posted 8January, 2017 Do you have to remove the expansion valve to crack the air box? Link to comment Share on other sites More sharing options...
Peter M Posted 8January, 2017 Report Share Posted 8January, 2017 No. That's my hazy recollection anyway!I found following the linked thread above worked well. Link to comment Share on other sites More sharing options...
T-Man Posted 8January, 2017 Report Share Posted 8January, 2017 Do you have to remove the expansion valve to crack the air box?Dont remember having to actually remove it, however at some point it needs to come off. Which evaporator are you replacing it with? Have you said goodbye to your loved ones for 10hours? Only 10 hours..... You did well! ? Link to comment Share on other sites More sharing options...
Peter M Posted 8January, 2017 Report Share Posted 8January, 2017 Only 10 hours..... You did well! ?Might have been 12 but time heals the pain! Link to comment Share on other sites More sharing options...
turboT Posted 8January, 2017 Report Share Posted 8January, 2017 Sometimes the ___ will go in to far and will actual jam the ____ so maybe try at different penetrations.Are you able to feel the back of the ____ while you do this so you might be able to feel when each side unlocks as you wiggle the ____.Pete? Link to comment Share on other sites More sharing options...
