michel Posted 6March, 2017 Report Share Posted 6March, 2017 Got a yellowed tired looking coolant/expansion tank .. like some a 924 turbo unobtanium and the sanctioned mod is a swap to a 944 unit.... or you could try bleaching or a hyd peroxide and laundry booster cocktail.so unless some prof sumner type here got a warning or better thought, I'm going to give this a go on the weekend.There is this little gem Link to comment Share on other sites More sharing options...
Rod C Posted 6March, 2017 Report Share Posted 6March, 2017 I have one on order from Porsche for approx $150.00 if that helps Michel. Link to comment Share on other sites More sharing options...
michel Posted 6March, 2017 Author Report Share Posted 6March, 2017 Thx Rod I'll take the test ? Link to comment Share on other sites More sharing options...
Rob Posted 6March, 2017 Report Share Posted 6March, 2017 Take note of what the man says about chlorine - you don't want a lungful of that - ask me how I know. I suspect the discolouration on the tanks is both internal and external, some due to heat and age and some due to chemical action and corrosion products from the cooling system. You'll need to remove the corrosion products before the treatment will work. Good luck with that - as you've probably found, the tank is a bit of a maze inside...Hopefully no news articles come up about a deadly chlorine cloud over Canberra... Link to comment Share on other sites More sharing options...
Dreamr Posted 6March, 2017 Report Share Posted 6March, 2017 Got a yellowed tired looking coolant/expansion tank .. like some a 924 turbo unobtanium and the sanctioned mod is a swap to a 944 unit.... or you could try bleaching or a hyd peroxide and laundry booster cocktail.so unless some prof sumner type here got a warning or better thought, I'm going to give this a go on the weekend.There is this little gem Michel,I have a much better soution for you ....Through my trawlings on the www, I picked up a handy little tidbit ....The expansion tank on our turbos is the same unit as on a 1981 VW Scirocco .... will set you back about $13.50 from a VW parts supplier or they are plentiful on ebay US ....Spend the money on a new tank and save your lungs.Hope this helps you all ..... Link to comment Share on other sites More sharing options...
Dreamr Posted 7March, 2017 Report Share Posted 7March, 2017 BTW ..... I forgot to let you all know that there are 2 x different types ....If you go this way, make sure you buy one WITHOUT the sensor hole ...... Link to comment Share on other sites More sharing options...
michel Posted 7March, 2017 Author Report Share Posted 7March, 2017 Cool.thx @Dreamr though will still go through with the experiment.life at moment only allows small projects FYI gents chlorine gas as per the guys u tube is a way. There are less risky damaging means to do this. Link to comment Share on other sites More sharing options...
