Cam Arnott Posted 2April, 2017 Report Share Posted 2April, 2017 I'm curious to know how hard it might be to retrofit air conditioning to a 968? Can anyone shed any light on the degree of difficulty with this? Can it be done like a factory installation using the existing HVAC? Thanks for any assistance. Cam Link to comment Share on other sites More sharing options...
944s2cab Posted 2April, 2017 Report Share Posted 2April, 2017 Following this with interest as I need to do my 944 cab Link to comment Share on other sites More sharing options...
Cam Arnott Posted 11April, 2017 Author Report Share Posted 11April, 2017 I spoke with Bruce Buchanan about this today who was very helpful.To cut a long story short you need a RHD donor car and about $10K to do the job factory style for a 968.I'd imagine a 944 would be very much the same.... Link to comment Share on other sites More sharing options...
Buchanan Automotive Posted 11April, 2017 Report Share Posted 11April, 2017 That should read about $10,000 including the 2nd hand parts from the donor car ( if you buy the donor Super Cheap ) and you spend the time dismantling , if the donor parts still work and do not leak ( GAS) & electrically work after all these years , so the variation on pricing will vary from $7,000 through to $15,000 , all depends on a 100 or so stars aligning & you're Gods are looking after you in buying a bunch of 25 to 30 year old A/C components that are quite often nearly stuffed before removal to very stuffed after removal from the donor carInevitably each case will be different & hence the amount of " New" components / parts that will be needed as the build goes on will vary greatly & to what level does the owner is happy to spend to get closer to perfectionPerfection is keeping an automotive A/C system working perfectly without any A/C gas ( Re-Gas) needed even after 5 or 6 years later & everything electrical is still working perfectly 5 or 6 years laterRemember 2nd hand electrical components that are already 25 + years old are usually at the end of their lives or Extremely close to it and or become intermittent in operationBrand new A/C components always work better than 2nd hand stuffRegardsBruce BuchananBuchanan Automotive Link to comment Share on other sites More sharing options...
