ANF Posted 18July, 2017 Report Share Posted 18July, 2017 Hi All,Does anyone have a used/ not working Auxiliary Air Valve to suit a 928 as per pic that they no longer need? Mine is playing up and I would like to have a look inside one/ maybe fix one before I pull mine apart as they are riveted together. The same part was used on other cars, Volvo's etc and maybe some other P cars?Thanks Link to comment Share on other sites More sharing options...
KGB Posted 18July, 2017 Report Share Posted 18July, 2017 Must you use the term, Volvo? I thought motor mounts were the end of it. Link to comment Share on other sites More sharing options...
ANF Posted 18July, 2017 Author Report Share Posted 18July, 2017 YES I must! I even have a black one in the garage!A lot of the K jet parts are interchangeable with Volvo's, Mercs and even BMWs!Volvo Volvo Volvo Volvo Volvo Volvo Volvo Volvo Volvo Volvo Volvo Volvo Volvo Volvo Volvo Volvo Volvo Volvo Volvo Volvo Volvo Volvo Volvo Volvo Volvo Volvo Volvo just in case you missed that!! Do you have one? Link to comment Share on other sites More sharing options...
tazzieman Posted 18July, 2017 Report Share Posted 18July, 2017 Must you use the term, Volvo? I thought motor mounts were the end of it.Mounts and radar guns Link to comment Share on other sites More sharing options...
Peter M Posted 18July, 2017 Report Share Posted 18July, 2017 Adam,Before you disassemble it could you just power it up and check the gate valve opens smoothly and then power it down and check it closes smoothly as the bimetal strip inside cools? Assuming it does this OK I would think the cause of your idle problem exists elsewhere.Regards Link to comment Share on other sites More sharing options...
ANF Posted 18July, 2017 Author Report Share Posted 18July, 2017 Hey Peter,I finally took it to someone recently and found out what was wrong with my car, the WUR was buggered so I put a rebuilt one on, car now flies but cold idle is rubbish. Guy who checked it out said this is from the AAV. I will test it but he said it was pretty gunked up inside. Just wanting to see if I can disassemble one to clean it properly without stuffing up mine. Link to comment Share on other sites More sharing options...
Peter M Posted 18July, 2017 Report Share Posted 18July, 2017 How about a good squirt of carb cleaner before you test it? Might just do the trick before you have to drill out the rivets! Link to comment Share on other sites More sharing options...
KGB Posted 19July, 2017 Report Share Posted 19July, 2017 Do you have one?Ar du galen? Jag ar en bil kille. Link to comment Share on other sites More sharing options...
ANF Posted 19July, 2017 Author Report Share Posted 19July, 2017 Clearly!! How about a good squirt of carb cleaner before you test it? Might just do the trick before you have to drill out the rivets!Armed with some carbie cleaner, contact cleaner, freezer and what ever else is needed to attack it.... see how it goes.... Link to comment Share on other sites More sharing options...
ANF Posted 20July, 2017 Author Report Share Posted 20July, 2017 Adam,Before you disassemble it could you just power it up and check the gate valve opens smoothly and then power it down and check it closes smoothly as the bimetal strip inside cools? Assuming it does this OK I would think the cause of your idle problem exists elsewhere.Regards Other way around Peter, it opens up when cold (freezer test failed to move it) and closes when you apply current/ gets warm (mine closed slightly when a bit warmer, will add some current to it later and test that it closes fully) - it appears mine will not open, hence the cold idle issues..... will try cleaning it .....?? Link to comment Share on other sites More sharing options...
ANF Posted 20July, 2017 Author Report Share Posted 20July, 2017 A bit of blackness came out, not a lot and not that bad. Valve moves freely with light pressure, so not fouled up anywhere inside, appears to be a fault/ issue inside...... So I either put up with crap cold running, pull mine apart and try to fix or buy another second hand one... hmmmm Link to comment Share on other sites More sharing options...
