brian in buddina Posted 12September, 2017 Report Share Posted 12September, 2017 I am just in the process of installing Koni yellow shocks and realize that I need to install 'bump stops.' Or do I??? Some foam inserts came with the rear shocks but nothing was supplied with the fronts.Where would I source them from? Is there any Australian supplier? Link to comment Share on other sites More sharing options...
OZ930 Posted 12September, 2017 Report Share Posted 12September, 2017 Koni Australiasales@wholesalesuspension.com.au Smooth Suspensionfor Koni rebuild and refurbtalk to Wayne0397351248I will have a look at my Koni installation notes, re the bumpstops, and get back to youYes, according to my instal instructions Link to comment Share on other sites More sharing options...
brian in buddina Posted 12September, 2017 Author Report Share Posted 12September, 2017 Oz930When I bought the car the PPI noted the bump stops had deteriorated & probably fell out. Link to comment Share on other sites More sharing options...
TINGY Posted 12September, 2017 Report Share Posted 12September, 2017 I am just in the process of installing Koni yellow shocks and realize that I need to install 'bump stops.' Or do I??? Some foam inserts came with the rear shocks but nothing was supplied with the fronts.Where would I source them from? Is there any Australian supplier? Mine need doing as well they have deteriorated also. Link to comment Share on other sites More sharing options...
90sF1Kid Posted 12September, 2017 Report Share Posted 12September, 2017 Mine were done this time last year. Notes on the PPI as well. Link to comment Share on other sites More sharing options...
brian in buddina Posted 13September, 2017 Author Report Share Posted 13September, 2017 I contacted the Koni rep, Toperformance Products which is the Distributor KONI Shock Absorbers, www.toperformance.com.au, and they don't make a rubber stop. They require you to re-use the original or get a replacement from Porsche. Here is the link to the front strut diagram: https://i.imgur.com/uR58zTD.png The Porsche parts I am looking for is, 'rubber stop', item 7, part number 951 343 527 00Also my car did not come with the 'boot', item 6, part number 431 412 135Is the boot required to hold the bump stop in place when you bottom out?Is the original boot plastic or metal? Toperformance suggested I try Fulcrum suspension. They have a web page, which lists common bump stop & other misc. suspension bits. This is the link: http://www.superpro.com.au/tradeview/index.php?view=universalpartsThe 1833BK looks close, I will call tomorrow & confirm that it will or won't work & what it cost. It comes with a boot in the kit. The Superpro link above also has lots of roll bar links, bushings & stuff. It may be worth looking at if your interested. I contacted Porsche parts in Brisbane. Stock is available in Melbourne, 3 day delivery plus extra to the Sunny Coast. Has anyone used the 1833BK??? Link to comment Share on other sites More sharing options...
brian in buddina Posted 15September, 2017 Author Report Share Posted 15September, 2017 Got a price from Fulcrum Suspension but delivery was after the weekend. A mechanical friend suggested I try Peddler's. They had the same bits as Fulcrum, but branded as Peddler, marginally cheaper and in stock on the Sunny Coast. Needless to say the P. parts where the most expensive. Here is a photo of there 3 Peddler's standard bump stops:https://imgur.com/gallery/dA3Tu I chose the one on the right, part #4359, which looked closest to the original P part, and the applicable boot, which is a bellows type. These boots should be better, I think based on my limited knowledge, than the P. brand because they would seal out road debris on the sliding shaft of my expensive brand new shocks. I stand to be corrected. It would be interesting to know what the actual height of the Porsche bump stop is in comparison to the #4359. Different bump stops for different model, I would think due to different ride height??? Maybe the our 944 @Buchanan Automotive can enlighten me on the original bump stop height? Link to comment Share on other sites More sharing options...
