Peter John Posted 1November, 2017 Report Share Posted 1November, 2017 got a nice chip on the freeway the other day- any contacts recommended? Or should I dial neirb’o? Link to comment Share on other sites More sharing options...
Lucky Phil Posted 1November, 2017 Report Share Posted 1November, 2017 If you have glass cover on insurance ($50 no brainer on all my cars) the fix is free. I'd suggest O'briens. I have used them and the end result is a small dot that is vitally invisible. As long as it is not on the drivers side all good, otherwise new windscreen is the only remedy, but if you have the glass option also free. Link to comment Share on other sites More sharing options...
Ozvino Posted 1November, 2017 Report Share Posted 1November, 2017 got a nice chip on the freeway the other day- any contacts recommended? Or should I dial neirb’o?if you have insurance go to Porsche and get a factory screen fitted - get an entire new screen; make sure that chip "spreads"..... Link to comment Share on other sites More sharing options...
OZ930 Posted 1November, 2017 Report Share Posted 1November, 2017 If the chip is fresh, and you intend to get it repaired, do not wipe or wash the area. Cover the chip with clear sticky tape before it gets any contaminants in the crack.If you want a do it yourself repair, kits are available from most auto parts stores for around $35. I have had good results with these and some not so good because I didn't / couldn't cover the chip before getting to the repair. Link to comment Share on other sites More sharing options...
