D2000 Posted 31January, 2018 Author Report Share Posted 31January, 2018 1 hour ago, TwoHeadsTas said: I'd also better look for those terminals in the engine area in the 996 too There is a pic of them here https://perryandcoblog.com/2009/11/17/porsche-carrera-911-996-dead-battery-locked-hood-solution/#comments Link to comment Share on other sites More sharing options...
911 Snake Posted 31January, 2018 Report Share Posted 31January, 2018 Can you simply disconnect the battery terminals and leave the frunk open if you're not using the car for a while? Link to comment Share on other sites More sharing options...
D2000 Posted 31January, 2018 Author Report Share Posted 31January, 2018 54 minutes ago, 911 Snake said: Can you simply disconnect the battery terminals and leave the frunk open if you're not using the car for a while? Apparently just need to disconnect the negative cable: https://www.edmunds.com/car-care/how-to-prep-your-car-for-long-term-storage.html But perhaps put something under the trunk lid so it can’t get closed accidentally as it will be a major hassle to get it open again to reconnect the battery Link to comment Share on other sites More sharing options...
911 Snake Posted 31January, 2018 Report Share Posted 31January, 2018 3 minutes ago, D2000 said: Apparently just need to disconnect the negative cable: https://www.edmunds.com/car-care/how-to-prep-your-car-for-long-term-storage.html But perhaps put something under the trunk lid so it can’t get closed accidentally as it will be a major hassle to get it open again to reconnect the battery AH! cool - sorry I should've just Googled but didn't know if there were any rules with P cars. Definitely need to make sure the frunk won't fully close and put some kind of make shift spacer there to prevent it from locking if pushed down!!! cheers! Link to comment Share on other sites More sharing options...
dan_189 Posted 31January, 2018 Report Share Posted 31January, 2018 20 minutes ago, 911 Snake said: AH! cool - sorry I should've just Googled but didn't know if there were any rules with P cars. Definitely need to make sure the frunk won't fully close and put some kind of make shift spacer there to prevent it from locking if pushed down!!! cheers! A sponge in between the bonnet and latch does the trick and won't damage anything Link to comment Share on other sites More sharing options...
