hepkat63 Posted 10February, 2018 Report Share Posted 10February, 2018 Hi all, i purchased a 'do a upper' 924 - 1980 model. Needs a lot of body work etc, but not too fused about that. My problem is that the cars starts, but won't rev. When you 'tap' the accelerator, you get nothing. When you put accelerator down, it just stalls. If you try to steadily accelerate, it does nothing then dies. So, what I've done: Drained the fuel tank Cleaned in tank fuel filter Put fresh fuel in tank Replaced Fuel filter, Spark plugs, leads, points. Checked rotor cap, coil and looked for anything loose or not connected. Checked all the hoses for vacuum leaks Pulled out plugs, did compression test - all good (well, good enough) Whilst plugs were out, put motor at TDC, checked rotor pointing to no.1 lead Checked timing - was 5+ - put to 10+ as per manual. Set points to 0.28 as per manual - put plugs to 0.35 as per manual. Kind of out ideas now. There is no doubt lots of things under the bonnet that have been stuffed around with, but being my first 924, don't have anything to really compare it against. So.... at the end of the day, can someone please suggest something that might be the issue? Link to comment Share on other sites More sharing options...
9fan Posted 10February, 2018 Report Share Posted 10February, 2018 Exhaust may be blocked creating back pressure. Link to comment Share on other sites More sharing options...
ANF Posted 10February, 2018 Report Share Posted 10February, 2018 From what you have already checked sounds like could be a fueling issue, either a lack of fuel or too much fuel, these are a K Jet system I believe? Get the WUR checked for pressures. Link to comment Share on other sites More sharing options...
ANF Posted 10February, 2018 Report Share Posted 10February, 2018 Also, when I did my 928 K jet system I found most seals and gaskets needed replacing, throttle body ones (was quite dirty inside too)! Fuel injector seals were all hard and starting to perish, I found a few cracked vacuum hoses, basically everything that could leak or crack or perish was replaced, it was all needed but the main culprit was the WUR. Check the condenser in the dist too, I have had cars in the past that simply would not run and replaced this and it was fine, worth a look and should be cheap. Link to comment Share on other sites More sharing options...
hepkat63 Posted 10February, 2018 Author Report Share Posted 10February, 2018 thank guy for the feedback. I'll look into those issues Link to comment Share on other sites More sharing options...
3legs Posted 10February, 2018 Report Share Posted 10February, 2018 As Adam said plus put new injectors in. Doesn't take much to stuff them up. Link to comment Share on other sites More sharing options...
jakroo Posted 11February, 2018 Report Share Posted 11February, 2018 check the fuel pump as well..... Link to comment Share on other sites More sharing options...
