AndrewW Posted 9April, 2018 Report Posted 9April, 2018 Ive been looking at the seats offered by Autotecnica in Victoria, on line. They offer great value and are ADR compliant, there seat rails are also ADR compliant. Has anyone had any experience with their seats and the company in particular in regards to after sales service and good practice ?
bumble Posted 10April, 2018 Report Posted 10April, 2018 I have had a pair in my SC for the last couple of years - manufacturing sticker says 2014. Comfortable, robust and supportive but not particularly light. I installed them because I had intentions of running the car in club sprints but changed my mind and put the originals back in recently. I fabricated my own seat mounts to get as much headroom as possible and so required a bit of patience to install. Available for $300 if you can get them to Adelaide... Cheers, Mark
AndrewW Posted 11April, 2018 Author Report Posted 11April, 2018 Hi Mark, Im looking at their cloth comfort seats that are ADR complaint plus their rails, is that you have ?
bumble Posted 12April, 2018 Report Posted 12April, 2018 Hi Andrew, I'm not sure of the exact type (maybe you can tell me!), but here are a few photos: The seat mounts are fabricated from 4mm aluminium angle to get maximum headroom - requires a bit of patience to install. I have some Porsche sew on patches to go over the button in the backrest. OOPS - something odd with accessing these files - I'll look into it.... So, looks like this site is very picky about how you enter stuff. Cut/paste/modify seems to cause big problems with URLs...
AndrewW Posted 12April, 2018 Author Report Posted 12April, 2018 They look like the ones Mark. Do the sliders work ? Are they from Autotecnica ? What height are you (requiring to lower them) ? Can you PM me with your location. Ill have to get a quote on transport. I don't suppose you need any front strut inserts or wheel spacers ?
hugh Posted 12April, 2018 Report Posted 12April, 2018 On 09/04/2018 at 9:39 PM, AndrewW said: Ive been looking at the seats offered by Autotecnica in Victoria, on line. They offer great value and are ADR compliant, there seat rails are also ADR compliant. Has anyone had any experience with their seats and the company in particular in regards to after sales service and good practice ? No.
bumble Posted 12April, 2018 Report Posted 12April, 2018 I can't comment on Autotechnica as a company - I never had contact with them. Their seats seem pretty robust albeit heavy. The seats that came out are Reccaro (SP?) electric adjustable (maybe 964/928 or something) and weight 23Kg although much more comfortable than good ole toombstones. I think the Autotechnicas weigh about 19Kgs AFAIR. The factory runners (sliders) work fine. I was going to make the car more track oriented and was looking for max headroom for a helmet. I'm 6'2" so need the height. I decided against this and leaving the car close to stock so put the Recarro seats back in. The mounts I made are two pieces of 4mm aluminium angle bolted together and could be redrilled to provide a higher seat height if needed (see the 5th pic from the top). I will say that mounting them is a bit of a faff and requires patience. Actually, I went into the garage the other day to check the suspension and ended up with a few bits left over... I am in Bundanoon in the NSW Southern Highlands about 2hrs south of Sydney.
symsy Posted 28June, 2018 Report Posted 28June, 2018 On 13 April 2018 at 12:13 AM, bumble said: I can't comment on Autotechnica as a company - I never had contact with them. Their seats seem pretty robust albeit heavy. The seats that came out are Reccaro (SP?) electric adjustable (maybe 964/928 or something) and weight 23Kg although much more comfortable than good ole toombstones. I think the Autotechnicas weigh about 19Kgs AFAIR. The factory runners (sliders) work fine. I was going to make the car more track oriented and was looking for max headroom for a helmet. I'm 6'2" so need the height. I decided against this and leaving the car close to stock so put the Recarro seats back in. The mounts I made are two pieces of 4mm aluminium angle bolted together and could be redrilled to provide a higher seat height if needed (see the 5th pic from the top). I will say that mounting them is a bit of a faff and requires patience. Actually, I went into the garage the other day to check the suspension and ended up with a few bits left over... I am in Bundanoon in the NSW Southern Highlands about 2hrs south of Sydney. Thats half a car
