my.name.is.URL Posted 16April, 2018 Report Posted 16April, 2018 Hi Folks, Just carried out an oil/oil filter change on my Cayman 987 & noticed a very faint whining/whistling noise upon driving the car again. Any suggestions on what it could be & whether it's connected to the oil change? Thanks in advance!
Skidmarks Posted 16April, 2018 Report Posted 16April, 2018 8 hours ago, my.name.is.URL said: Hi Folks, Just carried out an oil/oil filter change on my Cayman 987 & noticed a very faint whining/whistling noise upon driving the car again. Any suggestions on what it could be & whether it's connected to the oil change? Thanks in advance! Check your oil filler cap is on tight.
my.name.is.URL Posted 16April, 2018 Author Report Posted 16April, 2018 51 minutes ago, Skidmarks said: Check your oil filler cap is on tight. Hi mate, Yes I've already checked that but no luck.
dan_189 Posted 27April, 2018 Report Posted 27April, 2018 Long shot but did any oil happen to spill on the drive belt or pulleys?
bear924 Posted 13May, 2018 Report Posted 13May, 2018 Also check you didn't overfill the oil. Not sure if that would cause this noise, however is easy to do.
my.name.is.URL Posted 25May, 2018 Author Report Posted 25May, 2018 Update: the noise was unrelated to the oil change, turned out the water pump was dying. Thanks for your comments though!
