trm Posted 15March, 2019 Report Share Posted 15March, 2019 Hi all, Hi all, I am currently in the process of replacing my rear spring plates with new sway away adjustables. In the process I have found that the holes in the trailing arm appear to be flogged out. I presume this is because the bolts have been lose at some point and the movement had flogged out the holes in both the spring plates and the trailing arms. I have also posted this to the pelican parts forum to seek opinions. You can see most on there are suggesting it needs to be replaced. So it looks like I may need a left rear trailing arm for an 86 911. Anyone have one or know where I can get one? https://forums.pelicanparts.com/porsche-911-technical-forum/1023472-help-rear-trailing-arm-bolt-holes-damaged.html Link to comment Share on other sites More sharing options...
LeeM Posted 15March, 2019 Report Share Posted 15March, 2019 Good luck trying to find a new one, as I was told they are no longer available from Porsche and none in Germany, yet try Craig at Buik Motorworks here in Adelaide 82971400, as I reckon they had a second hand one I had an issue with mine 'apparently' after my little off last year, yet turned out to be just adjustment required. Link to comment Share on other sites More sharing options...
dipstick Posted 15March, 2019 Report Share Posted 15March, 2019 These are probably too early https://www.gumtree.com.au/s-ad/gladesville/auto-body-parts/porsche-911-spring-plates/1197483407 Aposchapart David Jenej Link to comment Share on other sites More sharing options...
MrRPJ Posted 25March, 2019 Report Share Posted 25March, 2019 easy fix to save the arm Drill out the hole slightly larger and press in a new machined ring back to oe size and get new spring plates Link to comment Share on other sites More sharing options...
