HWY Posted 13December, 2019 Report Share Posted 13December, 2019 When do you suggest/ know to change engine mounts? Not tracking, and not a GT.... but it is manual. 10 years/ 100,000km? And would you go stiffer than factory mounts? Thanks Quote Link to comment Share on other sites More sharing options...
JV911 Posted 16December, 2019 Report Share Posted 16December, 2019 I've had Wevo semi-solid mounts in a few cars and would recommend. They transfer a bit of extra noise to the cabin but that actually enhances the driving experience. Quote Link to comment Share on other sites More sharing options...
reggiegums Posted 16December, 2019 Report Share Posted 16December, 2019 On 13/12/2019 at 20:46, HWY said: When do you suggest/ know to change engine mounts? Not tracking, and not a GT.... but it is manual. 10 years/ 100,000km? And would you go stiffer than factory mounts? Thanks I've got a set of brand new RS 964/993 engine mounts if you're looking. Quote Link to comment Share on other sites More sharing options...
HWY Posted 17December, 2019 Author Report Share Posted 17December, 2019 Reggiegums, Thanks for the kind offer, but I think I will keep going on whats in the engine bay a bit longer. If I change I'll probably go something stiffer as JV911 suggests. Quote Link to comment Share on other sites More sharing options...
smit2100 Posted 17December, 2019 Report Share Posted 17December, 2019 2 hours ago, HWY said: Reggiegums, Thanks for the kind offer, but I think I will keep going on whats in the engine bay a bit longer. If I change I'll probably go something stiffer as JV911 suggests. @hwy. Seem very quick to dismiss 964RS mounts that aren't exactly your standard model production line based rubber factory mounts. I would describe them equally as a semi solid mount compared to a semi solid wevo mount but come with a factory part number . Application wise,subject to correct ordering and placement of washers, they can work across 911models i.e and function just as well on a watercooled 996 turbo as they do on an aircooled 964rs. I would also recommend doing tranny mount at the same time. Quote Link to comment Share on other sites More sharing options...
dan_189 Posted 20December, 2019 Report Share Posted 20December, 2019 I have 964 RS engine mounts in my 996 would highly recommend them - they are the same design as WEVO and RSS etc. although these are factory parts. I'd recommend a longer bolt if you're installing them on a 996. I have the details if you need them. Quote Link to comment Share on other sites More sharing options...
