WB997.2GTS Posted 18September, 2020 Report Share Posted 18September, 2020 As per the title, anybody have or know where I can purchase a yoke in the Sydney area. I could use my standard universal one but find they limit access to the rear of the engine. Quote Link to comment Share on other sites More sharing options...
Peter M Posted 18September, 2020 Report Share Posted 18September, 2020 Assuming you're talking aircooled, I found this guy good to deal with: https://www.thesamba.com/vw/classifieds/detail.php?id=956239 If I've got my assumption wrong, he also does ones for watercooled engines as well. I couldn't find anything local. Oldskl60 1 Quote Link to comment Share on other sites More sharing options...
Oldskl60 Posted 19September, 2020 Report Share Posted 19September, 2020 On 18/09/2020 at 19:15, Peter M said: Assuming you're talking aircooled, I found this guy good to deal with: https://www.thesamba.com/vw/classifieds/detail.php?id=956239 If I've got my assumption wrong, he also does ones for watercooled engines as well. I couldn't find anything local. I also went with the same👍🏼 Quote Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 27September, 2020 Report Share Posted 27September, 2020 On 18/09/2020 at 19:15, Peter M said: Assuming you're talking aircooled, I found this guy good to deal with: https://www.thesamba.com/vw/classifieds/detail.php?id=956239 If I've got my assumption wrong, he also does ones for watercooled engines as well. I couldn't find anything local. Does that mount allow for the heat exchangers to clear the vertical mounting so the motor can be rotated with the heat exchangers fitted? Quote Link to comment Share on other sites More sharing options...
Peter M Posted 27September, 2020 Report Share Posted 27September, 2020 1 hour ago, Mike D'Silva said: Does that mount allow for the heat exchangers to clear the vertical mounting so the motor can be rotated with the heat exchangers fitted? Mike, I don't know for sure as I ended selling my mount due to a 400km house move! If you have a look at the photos in the link it looks like there is enough clearance to do so. Quote Link to comment Share on other sites More sharing options...
