911Gbanger Posted 6January, 2021 Report Share Posted 6January, 2021 Hello everyone, This is my first 911 so be gentle lol. It’s a 964 C2 From first starting the car how long does it usually take for the oil level gauge to move to its correct level? Secondly, does the dipstick alway read as empty when the car is cold or should it show at least some oil ? I do know it is a dry sump but not entirely sure if that means it’s literally dry unlike a conventional engine with oil sitting in the sump? Thank you Quote Link to comment Share on other sites More sharing options...
tomo Posted 6January, 2021 Report Share Posted 6January, 2021 If I can remember the temp guage should be about the 8 oclok mark and you oil gauge should show a correct reading, To check your dip stick engine should be at correct temp , Make sure your car is on level ground, Clean D/S put back in tube wait about a minit check d/s again should read about 4 mm below max for correct level , And do this procedure with the motor running. 911Gbanger 1 Quote Link to comment Share on other sites More sharing options...
icu_jimmy Posted 6January, 2021 Report Share Posted 6January, 2021 Agree with Tomo, but in my view never trust the gauge and check the oil level regularly, Porsche advise to check every time you fill up. They do use oil, and they like to have a leak 😉 but a good engine won't use much. 911Gbanger 1 Quote Link to comment Share on other sites More sharing options...
reedminor Posted 6January, 2021 Report Share Posted 6January, 2021 Oil needs to be checked on the dipstick. Allow car to warm up - first mark on oil temp gauge. Leave engine running at idle Ensure car parked on level ground Check oil on dipstick with engine running, and adjust level as necessary. 500mls between empty and full on dipstick (check your owners manual) , so if you need to add oil I add in 200ml increments (using a marked cooking measuring cup now only used for oil filling) and recheck. I never use oil level gauge and trust it implicitly - but I do use it as a guide. No excuse not to check regularly - they do use oil Thanks Justin 911Gbanger 1 Quote Link to comment Share on other sites More sharing options...
911Gbanger Posted 7January, 2021 Author Report Share Posted 7January, 2021 Appreciate the help thanks guys 🙂 tomo 1 Quote Link to comment Share on other sites More sharing options...
