No Mans Land Posted 26April, 2022 Report Share Posted 26April, 2022 I am replacing the front number plate on my 87 Carerra, wanting to know how you guys fit our standard size plates properly? anywhere to buy a suitable bracket? Quote Link to comment Share on other sites More sharing options...
9er Posted 27April, 2022 Report Share Posted 27April, 2022 There is a factory bracket (s), most people just attach the number plate directly, I have a new bracket (actually two seperate brackets) but I just checked, it specifies 1965-73, but Im sure it would be the same. Quote Link to comment Share on other sites More sharing options...
Coastr Posted 27April, 2022 Report Share Posted 27April, 2022 Wow that looks nothing like mine. Though mine does mount the plate at angle downward which this one appears to correct. Quote Link to comment Share on other sites More sharing options...
No Mans Land Posted 27April, 2022 Author Report Share Posted 27April, 2022 3 hours ago, 9er said: There is a factory bracket (s), most people just attach the number plate directly, I have a new bracket (actually two seperate brackets) but I just checked, it specifies 1965-73, but Im sure it would be the same. Thanks 9er for the info on the bracket, will look it up. Cheers Quote Link to comment Share on other sites More sharing options...
81SC Posted 28April, 2022 Report Share Posted 28April, 2022 Info below from Design 911. 33 91170120100 support £22.26 33 91170105300 support M218 £49.17 33 91170120102 support M411 N/L/A 34 803955637 rubber washer £1.07 35 99959135402 prestole cage £1.65 36 N01152427 washer A 6,4 £0.20 37 90018711501 combination screw B 5,5 X 16 £3.64 38 99959149840 special nut £3.33 39 N0115228 washer A 4,3 £0.76 40 90014313400 tapping screw BZ 4,2 X 9,5 £1.45 Peter M 1 Quote Link to comment Share on other sites More sharing options...
