911 Posted 16November, 2022 Report Share Posted 16November, 2022 Hi all, not sure if this is common or not? I'm guessing the paint has disappeared because of it being a high friction area with engine vibrations. As you can see some surface rust has developed under my engine lid, where the base touches the rubber strip above the rear deflector. It was not too bad until recently when I drove it in the rain to get serviced and it must have sat for a while with the accumulated water there making it worse. Is there a way to make it look a bit better by removing the rust without damaging the surrounding paint. Or would I be better off leaving it? Not too keen on sanding it. Was thinking more of a cleaner or something along those lines that won't damage the paint. Thanks Quote Link to comment Share on other sites More sharing options...
Peter M Posted 16November, 2022 Report Share Posted 16November, 2022 Yes, common area of scuffing but you have excelled yourself! Suggest treating it with rust converter which will leave the bare metal a light gray colour and will delay further unsightly rusting. I've found Bondall Rustbuster good, particularly if warmed and kept warmed and readily available at Bunnings and the like. It won't damage the paint. Also suggest you check the rubber bumpers on the engine lid are correctly adjusted. My memory is that you can adjust their height by turning. Stepo and tomo 2 Quote Link to comment Share on other sites More sharing options...
911 Posted 17November, 2022 Author Report Share Posted 17November, 2022 For anyone following. I did exactly as per Peter's recommendation. Did the job! Peter M 1 Quote Link to comment Share on other sites More sharing options...
rminc Posted 17November, 2022 Report Share Posted 17November, 2022 21 hours ago, Peter M said: Also suggest you check the rubber bumpers on the engine lid are correctly adjusted. My memory is that you can adjust their height by turning. Mine is pretty scuffed too. Seems to be the norm really. My lid does look like it's in line with the fenders when closed height wise. If you turn the rubbers on the lid and adjust it so the lid sits higher, it may not rub? The only thing then is that lid will be higher than fenders and look out of alignment. Catch22.. Curious to know if there's a fix, before mine gets any worse. Quote Link to comment Share on other sites More sharing options...
911 Posted 20November, 2022 Author Report Share Posted 20November, 2022 On 17/11/2022 at 18:28, rminc said: Mine is pretty scuffed too. Seems to be the norm really. My lid does look like it's in line with the fenders when closed height wise. If you turn the rubbers on the lid and adjust it so the lid sits higher, it may not rub? The only thing then is that lid will be higher than fenders and look out of alignment. Catch22.. Curious to know if there's a fix, before mine gets any worse. I adjusted mine so the lid to sits higher to avoid the base that's scuffed touching, but it doesn't look right. Sits to high. I think over time with engine vibrations it's just part of wear and tear unfortunately. Quote Link to comment Share on other sites More sharing options...
