911 Factory Cassette Radio
911
Hi all,
My radio has started to play up. Wondering if anyone has the same one they'd be willing to part with?
Figure it's easier that getting an entire new unit, as I barely use it.
The top of my radio states the model is a MCC-2358P
Thanks.
Rare unit and rather expensive these days ..
There is a company in Melbourne that can service / refurbish yours if you choose to go down that path ..
They bought out Eurovox and all of their inventory back in the day ..
How much are we talking for used one or refurb? I was quoted $800 to replace with a continental unit, I think it was. Thought. I could get a standard one cheaper and justcchsne itvover myself.
20 minutes ago, TwoHeadsTas said:
$800 for a Continental sounds over the top - more like 1/3 - 1/2 of that to buy a unit if you want to install yourself
That price is installed. I was more looking to do a changeover of the factory unit myself.
Continental is an easy DIY install, but not sure of the plug configuration compared to your existing unit.  On later cars (eg 996) you need to swap the 3 and 7 pins so the ignition sense works correctly
  • 3 weeks later...
On 21/02/2023 at 00:20, Diamond911 said:
I had my 2358 refurbished by Vas the Eurovox technician. Can’t recall how much it cost.
he was selling refurbished 2358 units for about $2000 I seem to recall. Not many around though. Refurbishing may be your best bet
Thanks for the reply. I've messsaged him, so will see what he says.
Do you know if these run an amplifier or just the unit themselves?
Mine has the Eurovox amp as well which is located behind the passenger footwell.
Did you need to refurb that aswell, or just the unit?
Is this the amplifier? Sorry for the bad photo.
Likely to be swollen capacitors or failed transistors. Not difficult to fix by a techician as has been mentioned above on a radio that age. Keeps the original unit in place.
No, the amp didn’t require refurb, just the head unit.
I recall the Eurovox amp looked something like that. I probably have the model number at home. Will see if I can dig it up.
That would be great. Just want to confirm I have everything. I don't believe I have the 7 pin cannon plug though.
Not all units need the amplifier to run ..
Have a look at the wires coming out of the back of it ... if it has a plug that houses all of the wiring, then yes, need the amplifier ..If the power, earth, speakers, etc are separate out of the back, then no amplifier needed ..
Cheers ....
Cheers ....
It has a 7 pin plug, so it would require the amp.
The photo I've attached earlier was the cruise control module and not the amp. I can't locate the amp unfortunately, unless I'm completely missing it.
I also noticed this hose that was disconnected under the dash, does anyone know at its for
My Eurovox amp model is the MO-420, which is a 4x20W amp.  I can't provide a photo sorry as I don't have my 911 at the moment.  There is also a MO-480 but I believe the MO-420 was used more often by the late 80's.
This may well be the same amp but can't be sure:
VK GROUP 3 COMMODORE EUROVOX AMP HDT BROCK | eBay
