Simonk Posted 24August, 2013 Report Share Posted 24August, 2013 Can anyone tell me how to get it back in. There's a locking ring which looks like it needs to be turned to lock it in place but I can't figure out how to turn it with the lens already in the housing. Unless the the motor comes out some how? Link to comment Share on other sites More sharing options...
Russ Posted 24August, 2013 Report Share Posted 24August, 2013 i assume you've got the backing that the mirror is glued to? when I've seen them come apart the glass comes off the backing and is re-glued. Link to comment Share on other sites More sharing options...
Simonk Posted 24August, 2013 Author Report Share Posted 24August, 2013 I think so. The ring locks into the back of the lens ok. There's 4 tiny holes attached to the motor and 4 locating points on the back of the lens and the ring looks like it locks it all in place. Just buggered if I can figure out how to turn the ring to lock it Link to comment Share on other sites More sharing options...
clutch-monkey Posted 24August, 2013 Report Share Posted 24August, 2013 i literally just did this three weeks ago. i can do it if you put the mirror in front of me but no idea how to explain it haha there is a good explanation for it on pparts Link to comment Share on other sites More sharing options...
cyberpunky Posted 24August, 2013 Report Share Posted 24August, 2013 I am not sure if it is the same as late 85.5 944's but am guessing it will be similar method Clarks garage then click garage shop manual then scroll down to body section where you will find mirror removal and installation hope it helps Link to comment Share on other sites More sharing options...
Simonk Posted 24August, 2013 Author Report Share Posted 24August, 2013 I am not sure if it is the same as late 85.5 944's but am guessing it will be similar methodClarks garage then click garage shop manual then scroll down to body section where you will find mirror removal and installation hope it helps Got it! Thanks heaps Bruce. I was so close but didn't think to angle the mirror down so the lock ring lines up with the access hole at the bottom of the mirror. Link to comment Share on other sites More sharing options...
