duk Posted 8July, 2010 Report Share Posted 8July, 2010 Hi guys, looking for a suitable lsd to put in a 915 box that will see mainly track . Initially i was considering a quaife but have since been told that a modena unit is the better choice for track as it can be set to your own preference. looking for advice and where to get . thanks Duk Link to comment Share on other sites More sharing options...
AD911S Posted 10July, 2010 Report Share Posted 10July, 2010 Hi Try Stan at http://www.performance9.com.au/ Regards Peter Link to comment Share on other sites More sharing options...
Kerry Posted 11July, 2010 Report Share Posted 11July, 2010 Hi duk, Advise I was given when I asked the same question... "The LSD you want is the Modena ZF coarse spline for an early 915 box. They arent easy to get but they are far superior to a factory ZF LSD. Once you find one you then you can have it modified for your use. You could go with 40/60 if its mostly road use. Mine is setup at 50/80 which is pretty aggressive. They are made by Modena engineering but they only make a handful at a time and they are always back ordered. Spencer (Harrison) might be able to help you get one, its luck of the draw really." - blacklotus Just some extra food for thought... Kerry Link to comment Share on other sites More sharing options...
Cam Arnott Posted 13July, 2010 Report Share Posted 13July, 2010 Yep - The Modena unit is fantastic! Go for it Link to comment Share on other sites More sharing options...
duk Posted 20July, 2010 Author Report Share Posted 20July, 2010 Thanks for the advise, will pursuit the modena unit. regards Duk Link to comment Share on other sites More sharing options...
duk Posted 28July, 2010 Author Report Share Posted 28July, 2010 Ordered my modena lsd through spencer the other day and for those in the market they are available now. regards Duk Link to comment Share on other sites More sharing options...
Chris-p Posted 28July, 2010 Report Share Posted 28July, 2010 Good on you, Hope it does the job!! Cheers Chris Link to comment Share on other sites More sharing options...
Kerry Posted 28July, 2010 Report Share Posted 28July, 2010 Good work duk, looking forward to hearing your observations after its been in for a few squirty kms.... Cheers, Kerry Link to comment Share on other sites More sharing options...
Wobbly Posted 29July, 2010 Report Share Posted 29July, 2010 Would it be rude to ask how much $$$? Link to comment Share on other sites More sharing options...
duk Posted 9October, 2010 Author Report Share Posted 9October, 2010 Well it has been a while but the LSD saga continues. I should have retracted what i post about LSDs being in stock as it was clearly not the case. I wont go into details of what has happened but i have received a gripper LSD from the UK. Has anybody got, used or heard about these units? regards Doug Link to comment Share on other sites More sharing options...
