Grill inserts for the Boxster
withers
I agree with importance of paying for quality.
I bought fairly cheap ones off E-Bay when they arrived they had a convoluted process for attachment which involved drilling holes in the front bar and attaching with a combination of screws and zip ties.
In the end I had the front bar repainted by a panel beater so I had them fir the mesh.  They bonded them to the front bar using glue and this gave a much neater appearance.
Before attaching them I had them primed and sprayed in a matt black and they looked brilliant.  However within a couple of days they had chips and now they look a bit pock marked.
In hindsight if I went with cheap grilles again I would leave them silver, but in all likelihood would look at quality grilles that others have fitted which don't flake so you don't end up with a speckled look like mine:)
Cool thanks guys. So sounds like the zunsport might be the go then!
Would I need to remove them periodically to still clean behind the grills?   Other than cleaning the space in front well before fitment, anything else I should do or clean with to protect the space there??
  • 2 weeks later...
