How Do I Program the Seat and Mirrors to the Key?
Orion03
Stupid question time since I cannot figure it out.
I have electric seats and wing mirrors, great.
The seats and mirrors are linked to the key, i.e. use the key and all settings get set, great.
I can't figure out how to get the key and seat to remember my settings ! Bad !
I put the ignition on, hand brake on, push and hold the memory button, press and hold 1 .... but it doesn't work, every time I use the key to lock and unlock the car the seat and wing mirror changes
What am I doing wrong?
Push memory button and number 2 works to program my settings to 2... but not the key.
You will need these things:
  • The manual
  • Identify the keys from the screen
  • Lots of patience
  • The manual
  • & as Airhead says the 10 year old from down the road
OR
  • start the car,
  • get all your settings (seat, mirrors, sterring wheel) correct
  • hold the "Set" button in, then
  • press or hold in the door button with the key symbol on it until you hear a beep then it should be set
OR
  • go to the nearest Porsche Centre & they will do it for you in about 20 seconds
  • keep pressing all the buttons until you get it right
Good luck, by the way mine works.
I can get it to work for button 2 and button 3, but not the key !
I am going to try erasing all the memory and do it again, maybe that'll work.
I never had this problem in the Elise !!!
of course I didn't have any electrical stuff in the Elise... no carpet either.....  :)
:D  :D  :D  :D
I worked out the problem !
When the kind dealer changed the batteries in the remote key he must have swapped the PCB on the insides cause when I use remote key 2 the car says Key 1 and then when I insert the key it says Key 2
i.e. the transmitter for Key 1 is in Key 2
No wonder the car was confused, i.e. I unlock the car, it thinks I am using Key 1, and sets the seat and mirrors, then I put in key 2 into the ignition.
