Paul Carrera Posted 15May, 2014 Report Share Posted 15May, 2014 Just wondering how to remove the horn pad, I'm guessing it just pulls off but want to check so that I don't break anything Link to comment Share on other sites More sharing options...
Stew F Posted 15May, 2014 Report Share Posted 15May, 2014 I read about that style wheel when I was looking at how to do my 3 spoke wheel. Gently pull from both sides and it will come off. Then you need a 27mm socket to get the wheel off. Link to comment Share on other sites More sharing options...
OZ930 Posted 15May, 2014 Report Share Posted 15May, 2014 Hope this helps http://www.stuttswap.com/stuttswap/recover/whl_removal.html and http://www.pelicanparts.com/techarticles/Mult_Steering_Wheel/Mult_Steering_Wheel.htm DO NOT loosen the nut against the steering lock, release the lock then hold the steering wheel firm. The last note says to "pull that sucker off" but if it is a little stuck and releases suddenly, then you will end up with a steering wheel in your face. I would suggest loosening the nut about 1 turn then rock and pull until the nut is tight against the wheel. Repeat this process until the wheel is off. Link to comment Share on other sites More sharing options...
webrest Posted 16May, 2014 Report Share Posted 16May, 2014 Disconnect the battery first so you don't have the thing beeping especially when you are putting it back on. Rest of the info is correct. Link to comment Share on other sites More sharing options...
Paul Carrera Posted 16May, 2014 Author Report Share Posted 16May, 2014 thanks guys I will have a go this weekend Link to comment Share on other sites More sharing options...
Harvs11 Posted 16May, 2014 Report Share Posted 16May, 2014 Paul, Is that a Momo Prototipo I spy sitting on the floor waiting to go in? Share a pic. plz when you get it fitted. Link to comment Share on other sites More sharing options...
Paul Carrera Posted 16May, 2014 Author Report Share Posted 16May, 2014 good spotting Harv 100% correct - will do Link to comment Share on other sites More sharing options...
Quozl Posted 16May, 2014 Report Share Posted 16May, 2014 Paul, Is that a Momo Prototipo I spy sitting on the floor waiting to go in? Share a pic. plz when you get it fitted. That's mine but still need to work on the patina, that'll come with a few years use I imagine Link to comment Share on other sites More sharing options...
Paul Carrera Posted 24June, 2014 Author Report Share Posted 24June, 2014 New Prototipo all fitted super easy job only 10 min. Very happy with the result Link to comment Share on other sites More sharing options...
