SteveT Posted 9October, 2014 Report Share Posted 9October, 2014 Hi All, On my '76 Targa the drivers side window glass came loose so I pulled the door card off and the glass has just come out of the window regulator. I can kind of get it back in but it's not in all the way so I thought that whatever is supposed to hold it in is now stopping it from going back in properly. I can't see or work out what holds it in. Please help. Link to comment Share on other sites More sharing options...
Peter M Posted 9October, 2014 Report Share Posted 9October, 2014 Steve,I suggest you download the part manual called PET from the Porsche Classic site for your car. It shows how all the bits go together plus gives you the part numbers.Assuming the '76 is the same as the later air cooled cars, the window glass is supported by a folded steel u channel that has a rubber insert that relies on friction to keep the glass firmly attached to the channel. This channel is in turn attached to the window regulator scissor arms to make the window go up and downThe steel channel rusts after a while and loses grip on the glass and the two part company. The channel costs about $185US plus about $5US for the rubber insert from Pelican Parts.However, if your window glass has simply come out of the rubber support, you might find a squirt of silicon spray will assist you to wiggle it back into place. Link to comment Share on other sites More sharing options...
Peter M Posted 9October, 2014 Report Share Posted 9October, 2014 Link to comment Share on other sites More sharing options...
andrew911 Posted 9October, 2014 Report Share Posted 9October, 2014 this guy is awesome ..... I want him to move next door to me :-) Link to comment Share on other sites More sharing options...
Airhead Posted 10October, 2014 Report Share Posted 10October, 2014 Wind pressure. The faster you go the more secure they are!!!! Link to comment Share on other sites More sharing options...
clutch-monkey Posted 10October, 2014 Report Share Posted 10October, 2014 Wind pressure. The faster you go the more secure they are!!!! i don't know. i had a post it note stuck on my quarter window glass and it survived 180km/h! unless the glue has been upgraded.. Link to comment Share on other sites More sharing options...
SteveT Posted 13October, 2014 Author Report Share Posted 13October, 2014 Thanks peeps. No rust on mine so I guess it just came out. I am going to call Just James and see how much a new rubber thing to hold the window into the channel is going to cost and go from there. Link to comment Share on other sites More sharing options...
SteveT Posted 16October, 2014 Author Report Share Posted 16October, 2014 Picking up my new rubber thing that holds the glass in to the regulator in the morning. I was near PCBrisvegas yesterday so called in and ordered it for $24 not going to bother shopping around. Link to comment Share on other sites More sharing options...
SteveT Posted 29November, 2014 Author Report Share Posted 29November, 2014 Ok so there was rust on the channel that holds the glass in place, it runs along the bottom of the glass. I replaced the channel with a new shiny part from Porsche Australia for around $175 plus the rubber that holds the glass in place nice and snugly. Refitted door card and works fine. Link to comment Share on other sites More sharing options...
