Carrera86 Posted 18April, 2015 Report Share Posted 18April, 2015 Worth fixing ,or buy new Link to comment Share on other sites More sharing options...
Peter M Posted 18April, 2015 Report Share Posted 18April, 2015 About 150 buck USD for new genuine so you would have to weigh up whether it is worth fixing and considering how annoying it would be if it's not reliable:https://www.fcpeuro.com/products/porsche-seat-switch-911-944-928-968-80943022001I'd call James at Autohaus. Link to comment Share on other sites More sharing options...
Kris Posted 20April, 2015 Report Share Posted 20April, 2015 Mine just crapped out too. I found a post on pelican where someone pulled it apart and cleaned the contacts. I'd give that a go first. Link to comment Share on other sites More sharing options...
G5032 Posted 20April, 2015 Report Share Posted 20April, 2015 Search this forum, Pauly posted a similar fix not long ago with pics...i followed the instructions and managed to get mine working Link to comment Share on other sites More sharing options...
T-Man Posted 20April, 2015 Report Share Posted 20April, 2015 Not hard to repair. Link to comment Share on other sites More sharing options...
G5032 Posted 20April, 2015 Report Share Posted 20April, 2015 I used little bits of bluetac to hold the steel balls in place... Link to comment Share on other sites More sharing options...
Carrera86 Posted 23April, 2015 Author Report Share Posted 23April, 2015 I ended up just buying a new one , sit down with a beer and some glue and fix the old one for a spare perhaps Link to comment Share on other sites More sharing options...
Kris Posted 23April, 2015 Report Share Posted 23April, 2015 While we're on this topic - did both the back / forward and tilt switches fail at the same time? I was playing around with the 993 before and both switches are gone. Just before it failed, the back / forward movement was really slow, so I would have thought the other half would be ok. Link to comment Share on other sites More sharing options...
Peter M Posted 23April, 2015 Report Share Posted 23April, 2015 Kris, Could it be that you've blown the fuse? Two switches failing simultaneously sounds odd. Maybe the seat screw jacks require lubricating? Always something to be done on an old car! Link to comment Share on other sites More sharing options...
Kris Posted 23April, 2015 Report Share Posted 23April, 2015 Cheers Peter I'll check that out on the weekend When that was happening I was actually thinking 'power seats are an invention I don't need' Link to comment Share on other sites More sharing options...
Carrera86 Posted 26April, 2015 Author Report Share Posted 26April, 2015 Got the new one , 20 min to put it in ...works like a charm Link to comment Share on other sites More sharing options...
Kris Posted 4May, 2015 Report Share Posted 4May, 2015 Kris, Could it be that you've blown the fuse? Two switches failing simultaneously sounds odd. Maybe the seat screw jacks require lubricating? Always something to be done on an old car! Peter - spot on, thanks! Link to comment Share on other sites More sharing options...
