964 door trim repair
MartinE
Decided to check the door internals for rusty bits.
Good news, no rusty bits
Bad news, the driver side door card is badly water damaged.
The vinyl trim is in good condition so I think my best options are to either make a new door card myself, or find a motor trimmer who can make one for me.
What have others used to make door cards ( 3mm masonite, 2.8mm ply, other ?).
What is the best method to attach the vinyl to the new backing (staples, glue)
Any recommendations for a reliable motor trimmer in the Newcastle area.
Martin
I would use Masonite or craftwood. Craftwood would likely be closer to the original thickness. Sand the edge so it won't cut the cover. Use contact adhesive ( spray on from a craft shop probably easier) to fix the cover.
Edit: I would also seal the material against the weather after fixed. Best to make a new plastic backing as well if it's damaged. OMO
