SWEPCO Australia Posted 29August, 2011 Report Share Posted 29August, 2011 Swepco 201 Gear Oil Race-proven gear oil SWEPCO 201 Multi-Purpose Gear Lube is a premium quality, gear oil formulated to provide superior performance in a wide range of demanding operating conditions. It provides outstanding wear control, service life, cleanliness, thermal stability and corrosion resistance for most industrial gear boxes, manual transmissions, final drives and power take off units. It is blended from the finest high VI paraffinic base stocks available and the most advanced additive chemistry, including LUBIUM®, SWEPCO’s highly effective anti-wear additive. Features Special adhesive/cohesive formulation eliminates "dry starts", dramatically reducing initial start-up wear on pinion and ring gears Helps improve "stiff shifting" manual transmissions Reduces operating temperatures Anti-wear inhibitors and extreme pressure additives including SWEPCO's proprietary additive LUBIUM® Helps keep gearbox and transmission seals soft and pliable, reducing leakage Meets all AGMA specifications, API GL-5, and MT-1 EP and limited slip differential additives For more information or to order SWEPCO 201 Gear Oil; Please contact - Neil Taylor or John Mallia BH: 03 9318 9811 Mobile: 0419 913 532 (Neil) Mobile: 0411 411 177 (John)Porsche Article.pdf Link to comment Share on other sites More sharing options...
SWEPCO Australia Posted 30August, 2011 Author Report Share Posted 30August, 2011 http://www.facebook.com/editprofile.php?sk=contact&success=1#!/groups/swepco.australia/ Link to comment Share on other sites More sharing options...
SWEPCO Australia Posted 31August, 2011 Author Report Share Posted 31August, 2011 Check out the Youtube SWEPCO 201 Gear Lube demo! Link to comment Share on other sites More sharing options...
SWEPCO Australia Posted 12October, 2011 Author Report Share Posted 12October, 2011 20% Discount off SWEPCO ‘High Performance’ Lubricants for the Month of October! Please contact Neil Taylor or John Mallia; BH: 03 9318 9811 Mobile: 0419 913 532 (Neil) Mobile: 0411 411 177 (John) Link to comment Share on other sites More sharing options...
SWEPCO Australia Posted 28October, 2011 Author Report Share Posted 28October, 2011 Outstanding testimony from a SWEPCO 201 Gear Lube customer! "The good news is the gear lube is now in (after some fun struggles to get drain bolts out of an original 80's car) and the shift has indeed improved, I have less hesitation into 2nd gear now coming from either 1st or 3rd. It's not as slick as a modern jap gearbox, but its noticeably better than it was..." Check out our new ebay store - http://stores.ebay.com.au/slaaustralia My link Link to comment Share on other sites More sharing options...
Merv Posted 12December, 2015 Report Share Posted 12December, 2015 The link to your eBay store comes back to this site. Is there another link? Link to comment Share on other sites More sharing options...
ByronBayChris Posted 12December, 2015 Report Share Posted 12December, 2015 That was 4 years ago. Slaaustralia does not appear to have a shop on eBay anymore. I need to get my hands on some also. Let me know what you find. I've a couple of local leads. Link to comment Share on other sites More sharing options...
DHE11 Posted 12December, 2015 Report Share Posted 12December, 2015 John Malia at SLA in Melbourne was the importer and distributor you refer to above trading as "Swepco Australia", and Dan was the agent in NSW. Both are no longer active.Email "flatsixoils@gmail.com" if you want more info on sourcing Swepco oil and grease products. Link to comment Share on other sites More sharing options...
tazzieman Posted 13December, 2015 Report Share Posted 13December, 2015 http://www.hardcoretrayco.com/swepco.....and ask for David YoungIt's been 2 years , but he may still stock it. Link to comment Share on other sites More sharing options...
