michel Posted 6April, 2016 Report Share Posted 6April, 2016 anyone ever modded a 924 - stroker kits big valve high compression etcanyone ever dealt with EURORACE in the states? Link to comment Share on other sites More sharing options...
XLR8 Posted 7April, 2016 Report Share Posted 7April, 2016 Over on 924board.org there is a lot of info about what doesn't work on a NA 924 (most things) and what does (a few very expensive things). It seems chasing big power is usually achieved via forced induction (apparently the bottom end is bulletproof), or buying a 924 or 944 turbo.Keep us informed of what you find out. At best, most 924s could do with a rebuild now, and more grunt is certainly welcome. Link to comment Share on other sites More sharing options...
michel Posted 10April, 2016 Author Report Share Posted 10April, 2016 As you say plenty of talk on 924 board. Though was hopeful a local had been mucking about.might speak to Mr Buchanan, though am worried about the strength of invective and or equal measure ridicule and scorn, I will be subjected to once a 4 is added to the first two digits Link to comment Share on other sites More sharing options...
Buchanan Automotive Posted 10April, 2016 Report Share Posted 10April, 2016 Hi Michel , personally I think ( for decades) that the original 924 is an extremely good looking car & this can be put to the test by seeing what external colours ( any ) car can take well , so for example a same era 911 or 911 Turbo looks good in certain colours & conversely look dreadful in others , same goes for the 928 series it looks good in some colours but looks dreadful in other colours , but the 924 ( like the 944 ) looks good in just about any colour , that is the mark of an extremely good car shape / design & no one thinks about that , the shape is timeless , Porsche Germany has a 924 that is Signal Green in colour & is often used in the Porsche Classic Parts advertising & it looks fantastic And the 924 Turbo in a nice colour scheme looks fantastic & a ( rare ) 924 Carrera GTS , that still to this day looks sensational & then to top that the 1981 Hugo Boss 924 GTP Le Mans car , I would love to make a replica of that Years/ decades ago we had a customer Ron Curry who purchased a new 1980 931 ( 924 Turbo ) from the Porsche dealership I was working at in Sydney & he kept that car long after the lease expired because ( as I agreed with him ) it was a real lille stunner to look at , it was silver metallic from the waist up & dark blue metallic down low ( two tone ) & the interior was black with the Stuart Tartan cloth inserts on the seats & door trims , and with the green instrument dials it had a real expensive / exotic look about it Now the 924 in NA ( normally aspirated ) the 2.0L engine is actually a very nice little 2.0L engine , however being NA its never cheap to extract extra power , hence why Porsche thought it was worth the while to spend the money & make the 2.5L all alloy engine , either in the 2.5 NA as used in the 924S and 944 or in the later 944 models the very nice ( loves to be rev'ed ) 944S with its 2.5L twin cam 16V engine The standard Euro version 924 ( Non USA ) was I think 9.3:1 compression ratio , now the way I would increase output ( now that we have decent 98 octane premium unleaded petrol these days ) is to get made custom pistons made ( after inspecting the bores & seeing what to machine them to ) at around 11.5 : 1 compression ratio , decent set of custom headers / extractors & custom exhaust system & like we have done on some modified 3.0L 911 Sc's we get the K - Jet fuel list head modified to dial in the air fuel ratio at all rev rangers & probably a custom cam / in fact defiantly get a cam made to suite & of course a decent set of new con rods ( Wossner or Carrillo ) for reliability at high RPM , naturally this will cost a bundle , but that what it takes to get something out of a NA engine , I would be almost inclined to install a 944S ( 2.5 16V ) engine , but you will need a loner car , because you will need the engine & harnesses & computers , bell housing , flywheel , clutch , T Tube & while you are at it the transmission , but then you will need bigger front brakes because the one thing the 924 NA always had a issue with is the tiny front brakes , strongly the rear drum brakes on the NA 924 are actually quite OK , its the fronts that are the BIG issue along with the 4 stud wheel pattern , so that means you would need to graft the front & rear suspension & brakes out of the 944S and wheels , which is a shame because I like the look of the original 924 NA wheels , but there is another issue , the standard front brakes on the 944S were also CRAP , single piston sliding caliper , just like the 924 , but just a bit bigger , even the standard ( read small ) 4 piston Brembo front brake callipers & small discs used on the early 951 & as used on the 944S2 & 968 ( Non M030 ) were also CRAP , it wasn't until Porsche fitted the 951( 1988 Turbo S & 1989 Turbo S ) with the different ( Turbo S ) front axles & the BIG 4 piston Brembo front brake callipers from the 1986 928S that Porsche finally fixed the front brakes , these M030 Big front brakes were also an EXPENSIVE option on the 944S2 & 968 .I have a 968( last of the 944's) my self , a 1993 968 (6 speed) manual Non M030 ( standard little 4 piston callipers on the front )& it stops OK ish but NOT well at all as compared to the same car with the optional larger front brakes & yes I am going to update them because they are really quite SHIT if you have to stomp on them going down a hill at even 50 Kmh As you can see it took Porsche a long time to sort the brakes out & naturally the more performance you get the more you need stronger & stronger front brakesNote } We have done quite a few engine compression increases on the 3.0L 944S2 engines & we are doing one right now at work , we are taking standard 944S2 engine to the original 10.9:1 to 12.0:1 with custom 2nd oversize pistons & con rods we have had made by Wossner of Germany , this engine is getting some very nice custom ( read expensive ) custom made cams & and an entire Motec engine management system when complete , this engine is going to haul arse But my favorite Porsche engine , for simplicity & potential extra performance & ( lack of internal moving parts per output ) & the massive amount of power & drivability we regularly get out of them is the 944 turbo ( 951 ) in 2.5L we get ( depending on the stage we choose ) from 300HP to 450 HP & in regards to the 3.0L twin cam 16V E85 engines Sean Buchanan makes , they are generally between 570HP to 600 HP with 1.3 Bar boost on E85 & the 3.0L engine produces more torque / drivability over the 2.5L at all revs and it makes the 951 virtually a supercar in performance RegardsBruce BuchananBuchanan Automotive Link to comment Share on other sites More sharing options...
michel Posted 11April, 2016 Author Report Share Posted 11April, 2016 Hi Bruce great answer and consistent with our previous conversation Link to comment Share on other sites More sharing options...
