Stew F Posted 18December, 2016 Report Share Posted 18December, 2016 I want to start renovating my tail light housings over the next couple of weeks. One of them has corroded and needs some delicate repair work.How do I get the buggers off the car? I see 2 screws, but what do they screw into? Nuts, speednuts, panel? I did read that I can drill the heads off and put new screws in, but does that open up the proverbial can of worms? And enlighten me on these gaskets. Link to comment Share on other sites More sharing options...
Quozl Posted 18December, 2016 Report Share Posted 18December, 2016 Sent you a PM. Also if that info doesn't help try this thread on Pelicanhttp://forums.pelicanparts.com/porsche-911-technical-forum/451551-rear-light-removal.html Link to comment Share on other sites More sharing options...
Stew F Posted 18December, 2016 Author Report Share Posted 18December, 2016 Sent you a PM. Also if that info doesn't help try this thread on Pelicanhttp://forums.pelicanparts.com/porsche-911-technical-forum/451551-rear-light-removal.html?????? Link to comment Share on other sites More sharing options...
OZ930 Posted 18December, 2016 Report Share Posted 18December, 2016 This guy is a bit rough but it may helphttps://m.youtube.com/watch?v=wIEGaANLwjEFrom memory I had to unplug all the wires off the back of the reflector, so take a photo or draw a diagram.To get at the wiring you need to remove the backing plate. Two screwsHave fun. Link to comment Share on other sites More sharing options...
Stew F Posted 18December, 2016 Author Report Share Posted 18December, 2016 This guy is a bit rough but it may helphttps://m.youtube.com/watch?v=wIEGaANLwjEFrom memory I had to unplug all the wires off the back of the reflector, so take a photo or draw a diagram.To get at the wiring you need to remove the backing plate. Two screwsHave fun.the screws in the backing plate are a bit rusted in. I put some penetrating oil on them. I'll have another crack at them tomorrow night. Link to comment Share on other sites More sharing options...
Al Posted 19December, 2016 Report Share Posted 19December, 2016 Mine were pretty buggered and brittle so I replaced them with the aftermarket plastic housings from Design 911 in the UK. Lightweight and shiney. Put the original lense covers back on and the old housings stored away in a box. All looks completely stock.These and other parts can be found here..https://www.design911.co.uk/#parts;category-id%3D192 Link to comment Share on other sites More sharing options...
Stew F Posted 28December, 2016 Author Report Share Posted 28December, 2016 So, the latest development. My rhs housing is toast. I haven't had the lhs out yet, but I suspect it's not much different. New housings from Porsche are $700 odd each, plus $250 per lens. So I've ordered a pair of repo lights from Design911. $600 landed, with lenses. I just ordered4 new captive nuts from PCAdelaide at under $20. They are now brass, instead of steel as they originally were, so I'm going to replace all of them, and new screws.The only other thing I would add is it's probably a good idea to remove the lights every year or so. I think I removed a kilo of dirt from just the right hand side. It seems like a difficult place to get the hose into to clean out.I'll post again when the light arrive. Link to comment Share on other sites More sharing options...
LeeM Posted 28December, 2016 Report Share Posted 28December, 2016 Good work fellaThough whats this slammed 911 render all about then? Link to comment Share on other sites More sharing options...
Stew F Posted 28December, 2016 Author Report Share Posted 28December, 2016 Good work fellaThough whats this slammed 911 render all about then? It's just something I was mucking around with on 3DTuner. Just getting some ideas out of my head. It's supposed to be white, but white doesn't render very accurately. Link to comment Share on other sites More sharing options...
LeeM Posted 28December, 2016 Report Share Posted 28December, 2016 Thought your next project was going to be fitting airbags or something nuts like that! Link to comment Share on other sites More sharing options...
Stew F Posted 1January, 2017 Author Report Share Posted 1January, 2017 My son has a set of electric adjustable coilovers off his 200SX. Maybe I should try to fit them. Link to comment Share on other sites More sharing options...
