Plugger2 Posted 5January, 2017 Report Share Posted 5January, 2017 So, been looking at 987.1 Cayman S models, and I've been reading a bit about PASM. Sounds like a nice option for comfortable city driving, while allowing for a stiffer setup when the driving conditions are suitable -- in practice, much like the double-valved KWv3 set up I currently have on my 944 S2 (and like very much).But obviously, PASM is a more complex and sophisticated technology. Any downsides? For example, are there limitations if wishing to go with alternative shocks at some later stage (I realise the PASM would no longer work), but would, say, ordinary Cayman sports shocks fit? Are the PASM shocks serviceable, and by whom?Any insights appreciated. Link to comment Share on other sites More sharing options...
Raven Posted 5January, 2017 Report Share Posted 5January, 2017 I have it on my 997 S and rate it gives you the best of both worlds and work fantastic for high performance road use ,,,not sure about servicing or replacement never had an issue with it .............. Link to comment Share on other sites More sharing options...
Apogee Posted 6January, 2017 Report Share Posted 6January, 2017 Bilstein make PASM compatible coilovers if you wish to go third party later on.https://www.ecstuning.com/b-bilstein-parts/coilover-suspension-kit/49-122046~bil/ Link to comment Share on other sites More sharing options...
Plugger2 Posted 6January, 2017 Author Report Share Posted 6January, 2017 Bilstein make PASM compatible coilovers if you wish to go third party later on.https://www.ecstuning.com/b-bilstein-parts/coilover-suspension-kit/49-122046~bil/ Thanks, very useful info! Link to comment Share on other sites More sharing options...
Ian718 Posted 27October, 2017 Report Share Posted 27October, 2017 I have it on my 997 S and rate it gives you the best of both worlds and work fantastic for high performance road use ,,,not sure about servicing or replacement never had an issue with it ..............Hey Raven, I'm looking to buy a 718 Boxster for my first Porsche, and am possibly interested in PASM.When you say PASM gives the best of both worlds do you mean turning it on sport makes the rides stiffer/more responsive than a car without PASM, but leaving PASM on normal mode actually make it more comfortable (for driving to the shops) than a car without PASM? Or is PASM normal mode already stiffer than without PASM, and PASM sport mode just ridiculously stiff (for track)? Also does PASM lowering a Boxster/Cayman by 10mm mean you start scraping the front undersurface of the car all the time on speed bumps and driveways? Link to comment Share on other sites More sharing options...
Raven Posted 27October, 2017 Report Share Posted 27October, 2017 Hey Raven, I'm looking to buy a 718 Boxster for my first Porsche, and am possibly interested in PASM.When you say PASM gives the best of both worlds do you mean turning it on sport makes the rides stiffer/more responsive than a car without PASM, but leaving PASM on normal mode actually make it more comfortable (for driving to the shops) than a car without PASM? Or is PASM normal mode stiffer than without PASM, and PASM sport mode just ridiculously stiff (for track)? Also does PASM lowering a Boxster/Cayman by 10mm mean you start scraping the front undersurface of the car all the time on speed bumps and driveways?Yes if I turn it off I get a more comfortable and softer ride and on our Sh*ty roads that gets used often ,I have some really rough roads in my area ,,,,when I turn it on the car becomes very stiff with no give perfect for the track but sometimes to stiff for public roads ,,you get the choose of what you think is best ..........Also if you have sports chrono with it the activation of the Traction control is raised to a much higher thresh hold before the electronic nanny,s intervene and you can get the car to move around a slid a little before the TC takes control again Porsche Factory documents explaining the systems FOR 2005, PORSCHE EXPANDSTHE TECHNOLOGY ENVELOPESports Chrono Package Plus lets the 911 driver dial in preferred performance parametersFor Porsche, the ultimate challenge is always to push the limits of possibility. From the company’svery beginning, Porsche has explored and expanded the limits of performance, through competitionon the racetrack and with innovative technology engineered to enhance the driver’s daily experienceon the road.Throughout its proud history, Porsche has been respected for the dynamic quality of its vehicles andfor the engineering expertise and technological innovations that make those vehicles so safe, sosecure and, yes, so exciting to drive. Now, for the 2005 model year, an already impressive list ofengineering innovations expands with the introduction of the Sports Chrono Package Plus.Porsche Active Suspension Management for the 911There are two versions of Porsche Active Suspension Management, one for the Cayenne sport utilityvehicle and the other for the 2005 Porsche 911 Carrera and 2005 Porsche 911 Carrera S.For 2005, Porsche Active Suspension Management is standard equipment on the 911 Carrera S andoptional on the 911 Carrera and uses active damper technology to provide both a comfortable yetsporty suspension setup for regular driving and very aggressive settings for performance driving.Compared with the standard suspension, PASM lowers the entire car by 0.39 inches (10 mm).Further, by pressing a button on the center console, the driver can chose between normal and sportsettings.The normal setting provides a more comfortable damper setting that changes gradually to a sportingmode as the driver adopts a more dynamic style of driving. For example, when cruising down thefreeway, the normal setup absorbs minor and medium bumps more smoothly than the standard 911suspension.On the other hand, the sport mode activates a firmer damper control map for agile, dynamic drivingstyles and minimizes body roll to the point that lap times in testing on Germany’s famed Nuburgringracing circuit were reduced an average of five seconds per lap compared to the standard 911suspension setup.Porsche Active Suspension Management for the 911 links adaptive dampers and a pair ofaccelerometers that track vertical movements of the body with a control unit. Active dampers have asimilar structure as standard shock absorbers, but also have a bypass valve in addition to the regularopening in the main piston so oil flow can be increased or reduced as needed to infinitely adjustdamping forces. In the event of a system failure, the valve closes automatically and PASM maintainsits hardest position to provide the safest dynamic driving mode.2005 Porsche Technology / 2One accelerometer is mounted on the top of the right front damper dome and the other on top of theleft rear dome. The control unit compares reading from these accelerometers with lateralacceleration, steering angle, road speed, brake pressure and engine torque to determine optimumdamper control for each wheel.PASM has five specially developed software modules to assure excellent performance in all drivingconditions:• The lane change module responds to fast movements of the steering wheel and instantaneouslyincreases damper forces on both axles to better control lateral forces and improve handling inextreme dynamic situations.• The vertical control module does two things: in the normal setting, it increases damper forceswhenever vertical movement of the car’s body exceeds a certain threshold, for example, on a bumpyroad; in the sports mode, the system slightly reduces the damping effect to maintain better wheelcontact to prevent the car from “jumping” around while assuring good ride comfort.• The lateral acceleration module increases damping effect through a turn as a function of road speedand lateral acceleration to enhance driving precision.• The brake module responds as soon as the driver starts to apply the brakes and switches to aharder damping effect to reduce body “dive” to assure faster transmission of braking forces to theroad to optimize braking performance. Then, during brake application, the system switches to asofter control setting after a certain period, applying different forces to the front and rear axles asneeded. This is particularly effective on bumpy roads, where it assures better surface contract andshorter stopping distances.• The load change module switches damper control maps and establishes different damping forces onthe front and rear axles in all-out acceleration, when the driver lifts off the accelerator or shifts gears.This prevents the car from developing too much “squat” in normal driving. In the sport setting, thesystem briefly switches to a softer damper response to improve traction when accelerating on abumpy road.Sports Chrono Package Plus: Much more than a stopwatch, it sets higher dynamic parametersA clock-style gauge mounted on top of the dashboard of the 2005 Porsche® 911® Carrera® or 2005Porsche 911 Carrera S signals that this car is equipped with Porsche’s newest technologicalinnovation: the Sports Chrono Package Plus.While there are several sports cars available with a built-in stopwatch, Porsche’s Sports ChronoPackage Plus does much more than record sprint or lap times. Of course, Porsche’s Sport ChronoPackage Plus does include a stopwatch and lap-counting function, and uses the PorscheCommunication Management (PCM®) system to provide graphic display of such information. ButPorsche’s Sports Chrono Package Plus also allows the driver to engage more aggressively setelectronic control maps for the Motronic engine management system, for the Porsche StabilityManagement (PSM), for the Porsche Active Suspension Management (PASM) and for the Tiptronic®S transmission (on vehicles equipped with these options).By pressing a button on the center console, the driver engages Sports Chrono Package Plus to takedriving dynamics to a standard never before available. Under Sports Chrono Package Plus, changesare effected to the gas pedal control lines, engine speed limiter, engine throttle butterfly, PSM, PASMand Tiptronic S.When the Sports telltale lights up on the center portion of the gauge cluster, the driver knows that theE-gas control line has switched to a steeper configuration that puts the Tiptronic S in its manual mode,thus the throttle butterfly responds more quickly to movements of the gas pedal and the driver enjoyseven more spontaneous response from the engine. Should the driver keep the accelerator pedal fullydepressed without shifting gears, the engine speed limiter in gears 1-5 intervenes far more abruptlythan in routine driving. Shifts become less oriented to comfort and the throttle butterfly closes faster2005 Porsche Technology / 3when the driver lifts off the accelerator pedal, thus providing a more dynamic driving experience, moresimilar to the feedback a racer gets from a car on the track.The operation and intervention of PSM also changes to provide greater agility. For example, whenaccelerating out of turn in the Sports mode, higher anti-spin control thresholds allow more slip fromthe rear wheels. This can result in even faster acceleration because PSM does not intervene asquickly. Likewise, other PSM thresholds, such as those that control the anti-lock braking system, alsoare raised to a level that allows more dynamic control by the driver before the system intervenes. Andthe particularly skilled driver retains the option of switching off the PSM system and taking manualcontrol of the car’s dynamic direction.Under the Sports Chrono Package Plus, the PASM also switches automatically when needed to asports program that provides firmer suspension settings, reducing even further body lean throughcorners and enhancing contact between the tires and the road surface. However, there arecircumstances, such as on wet or snowy roads, in which an aggressive driver knows that a “softer”suspension setting can enhance traction and thus the PASM button can be pushed to put the car in itsnormal setting even when the sports mode is active.So the driver can graphically verify the improved dynamics of the 2005 Porsche 911 Carrera and 2005Porsche 911 Carrera S equipped with Sports Chrono Package Plus, the driver can push a stalkattached to the left side of the steering column to record various route segment times, which can bereviewed graphically on the PCM screen.The Sports Chrono Package Plus is just the latest in a long list of Porsche technological innovationsavailable on 2005 models of the 911, Turbo or Cayenne® sport utility vehicle. Information on othertechnologies follows: Link to comment Share on other sites More sharing options...
Ian718 Posted 27October, 2017 Report Share Posted 27October, 2017 Thanks Raven. PASM sounds like the way to go! Link to comment Share on other sites More sharing options...
Raven Posted 27October, 2017 Report Share Posted 27October, 2017 It was an option I had to have along with Chrono took me a while to find it too most 911 I looked at didn,t have either ,,,changes the character of the car dramatically .. Link to comment Share on other sites More sharing options...
