Tong Posted 21May, 2017 Report Share Posted 21May, 2017 hi guysi have just returned from overseas holiday and washed my car today in my garage.the car is on and I use water to wash it exteriorly. Found the steam coming out from the engine cabin. I think it's because the water get thou the cover and get into hot engine. ( I haven't opened the engine cover, it's closed when I washed.Then i turned the car off to avoid any damage. just wondering for this kind of car, what is the best way to wash it? To avoid any potential demage?Or it's just normal to wash it in hot engine. thanks guys Link to comment Share on other sites More sharing options...
Mike737 Posted 21May, 2017 Report Share Posted 21May, 2017 I'm assuming it was just a little bit of steam coming from the engine bay and the car was warm at the time. Most of the time the steam comes from the stock mufflers and heat shields I've noticed on a cold day and sometimes out of the wheel wells. If you open up the bay while the car is on you will easily be able to confirm the source of the steam. As long as you don't point the hose directly down the engine bay air intake you shouldn't have an issue washing. Link to comment Share on other sites More sharing options...
dan_189 Posted 24May, 2017 Report Share Posted 24May, 2017 Also avoid automatic car washes I've read quite a bit about how they have caused various minor issues. Link to comment Share on other sites More sharing options...
Pokiou Posted 25May, 2017 Report Share Posted 25May, 2017 As the Germans would say: Das ist normal, keine Sorge Link to comment Share on other sites More sharing options...
JLD Posted 2July, 2017 Report Share Posted 2July, 2017 Also avoid automatic car washes I've read quite a bit about how they have caused various minor issues. NEVER use an automatic car wash unless you don't care about your car. They are terrible with paint, and good for breaking external fittings Link to comment Share on other sites More sharing options...
Russ Posted 2July, 2017 Report Share Posted 2July, 2017 the touchless ones are okay, but it will take every bit of wax and sealant on your car off (which is what I use it for..) Link to comment Share on other sites More sharing options...
