Jim45 Posted 3July, 2017 Report Share Posted 3July, 2017 Been thinking I want more growl out of the car and a gundo / fister may be the way to go.Was going to mod my current mufflers but they are after market and don't really want to ruin them - maybe better to buy some bog standard mufflers and mod them.Anyone know if the early mufflers from a 996.1 will fit a 996.2?CheersJim. Link to comment Share on other sites More sharing options...
Pokiou Posted 3July, 2017 Report Share Posted 3July, 2017 You already have after market mufflers??? why not just by pass them with a bypass pipe? Link to comment Share on other sites More sharing options...
quasio Posted 4July, 2017 Report Share Posted 4July, 2017 lol i think i'm opposite, i've got aftermarket and actually want stock with gundo to go quieter. But i keep flip flopping.btw, i believe Russ has a pair of 996 exhausts, i believe they are C4S, and random reports are they may or may not fit C2's. If you have aftermarket, wouldn't this be louder than gundo anyway? or are they stock aftermarket? Link to comment Share on other sites More sharing options...
Jim45 Posted 4July, 2017 Author Report Share Posted 4July, 2017 Cheers for the replies..I have Cargraphic mufflers already and it does sound nice - was just wondering if it would be more aggressive with Gundo'd stockies.Not sure where the Cargraphic's sit in regard to noise tbh......i.e step up or step down from Gundo'd stockies.I think bypass will be too mental for my daily and I've read it will make the car drone...Initial post was a thought as I've seen a set of OEM's for $150.Jim. Link to comment Share on other sites More sharing options...
Pokiou Posted 4July, 2017 Report Share Posted 4July, 2017 Drone depends on the size of the bypass valve you use. 1.25" will give a nice note with no drone 2" will annoy the fook out of you. Link to comment Share on other sites More sharing options...
quasio Posted 4July, 2017 Report Share Posted 4July, 2017 i always thought it was this in order of loudness:StockGundo/Fister - idle quiet- on the beans a little extra.most aftermarket - grumble everywhere.full exhaust/ x pipe whatever else plus aftermarket.When you say bypass, you mean gundo hack? pipe joining inlet and outlet of the exhaust? Too many meanings floating around.Heard a lot of good things about the cargraphic though.edit:Is yours the TUV none? https://www.youtube.com/watch?v=ZUe7VZp0Peo Not too loud actually. Link to comment Share on other sites More sharing options...
Jim45 Posted 4July, 2017 Author Report Share Posted 4July, 2017 Gundo and Fister are semi bypass I suppose...Bypass cuts out mufflers altogether....Stop me if I'm barking up the wrong tree....Jim. Link to comment Share on other sites More sharing options...
Simonk Posted 5July, 2017 Report Share Posted 5July, 2017 996.1 and 996.2 C2, C4, C4s all have the same mounting points and will fit the same muffler. The stock 996.1 muffler internals are different to the 996.2 muffler and requires a different modification to achieve the semi bypass. 996.1 has a joining pipe between the inlet and outlet pipe. 996.2 has a pipe that comes from out of the can into the outlet pipe. I don't know what the result would be if you put a 996.2 modded muffler on a 996.1. I had Fisters on my car. I think the bypass was about 2". They didn't drone but was still loud when you gave it some beans. I found them annoying with my tiptronic when just plodding around but would have kept them if I had a manual. Here's a video. Having been in Mike's 996.2 with Cargraphic mufflers, the Fisters were quite a bit louder. Maybe Cargraphic do a couple different noise levels though as I've seen others on Youtube that seemed comparable in volume to the Fisters. If you can pick up OEM for $150 and get them modded for a couple hundred, you could sell them at a profit if you didn't like them. Link to comment Share on other sites More sharing options...
quasio Posted 5July, 2017 Report Share Posted 5July, 2017 Actually yeah that's pretty loud, sounds like mine actually.I guess in the end it's all hard to tell unless you're there in person.i think i just need that PSE exhaust switch valve. Link to comment Share on other sites More sharing options...
Simonk Posted 5July, 2017 Report Share Posted 5July, 2017 Because mine's a tip and a daily, I ended up going back to the stock mufflers and doing the Hemholtz box bypass which ups the induction noise over 4,000rpm. It added a few db when you mash the fun pedal. My bro even commented that he loves how it screams when you give it some beans. Link to comment Share on other sites More sharing options...
Jim45 Posted 5July, 2017 Author Report Share Posted 5July, 2017 Cheers for the response .I have the modded air-box as well, was already done when I bought the car, it does make a difference. (I have the original part as well).Should be near the top of the "to-do" list for a new 996 owner!Jim. Link to comment Share on other sites More sharing options...
Macca Posted 5July, 2017 Report Share Posted 5July, 2017 The "bypass pipes" are horrible. My friend that sold me his Porsche had them for about 2 weeks and changed back to stock. He purchased the fabspeed ones. http://www.fabspeed.com/996-carrera-muffler-bypass-pipes/ it sounded like having no muffler (as it didnt) . On the rev's it did sound cool but way too loud for any sane person ,drone and hollow idle. Apartently the afterhours muffler (acording to US forums) seem to be the loudest without bypass - again comes with drone etc etc. http://www.afterhoursautomotive.com/porschemufflers.htmlI have the gundo hack. Its a nice sound. Link to comment Share on other sites More sharing options...
Pokiou Posted 6July, 2017 Report Share Posted 6July, 2017 I'm planning to do the gundo very soon.. i just cant be bothered taking the mufflers off Link to comment Share on other sites More sharing options...
Harry Posted 22July, 2017 Report Share Posted 22July, 2017 Hi,I recieved this exhaust from Kline Innovation for my 996 C4S the other day. I'll let you know what it is like once it is on the car. Cheers,Harry. Link to comment Share on other sites More sharing options...
Pokiou Posted 24July, 2017 Report Share Posted 24July, 2017 That does NOT look cheap lol. Link to comment Share on other sites More sharing options...
smit2100 Posted 24July, 2017 Report Share Posted 24July, 2017 Hi,I recieved this exhaust from Kline Innovation for my 996 C4S the other day. I'll let you know what it is like once it is on the car. Cheers,Harry.Good choice. I have a Kline on my 996 turbo with 100 cel HJS cat. Good quality welds, very subtle at idle, civilized up 5000 rpm and above that GT3 overtones . But who gives a toss about noise as the primary reason for upgrading, eg throttle response was better and very noticeable over stock. Be interesting to see what Link to comment Share on other sites More sharing options...
quasio Posted 26July, 2017 Report Share Posted 26July, 2017 looks pretty nice, gt3 overtones ..mmmm.. yes please.. but alas i don't have a turbo either.can i ask how much it cost? and post a youtube something with a sound clip! Link to comment Share on other sites More sharing options...
