SteveF Posted 20August, 2017 Report Share Posted 20August, 2017 The under bonnet insulation in my 944 needs replacing as it literally falls apart when you touch it. For anyone who has removed theirs, what products have you used?Thanks in advance for your suggestions. Link to comment Share on other sites More sharing options...
Dreamr Posted 20August, 2017 Report Share Posted 20August, 2017 Just stare at it mate and it'll fall off in fright!!! Link to comment Share on other sites More sharing options...
ANF Posted 20August, 2017 Report Share Posted 20August, 2017 I have started the process but it looks to be a long one... have used goo gone so far with limited success, I really need to look at it again Link to comment Share on other sites More sharing options...
Timm Posted 20August, 2017 Report Share Posted 20August, 2017 Fuel worked a treat with mine. It dissolved all the adhesive and turned it into goo which could then easily be scraped of with some credit cards. Just don't light any matches while you're doing it Link to comment Share on other sites More sharing options...
Ozvino Posted 20August, 2017 Report Share Posted 20August, 2017 When I replaced the under-bonnet insulation on my 928 I used kerosene and oil/grease remover (pre-paint chemical) and it worked fine. Bonnet off, laying flat on a blanket on grass with drop sheet. I used a plastic scraper and it took probably an hour. I cleaned up all of the old glue and the applied the replacement pad after making sure it was dry, it worked great Link to comment Share on other sites More sharing options...
ANF Posted 20August, 2017 Report Share Posted 20August, 2017 When I replaced the under-bonnet insulation on my 928 I used kerosene and oil/grease remover (pre-paint chemical) and it worked fine. Bonnet off, laying flat on a blanket on grass with drop sheet. I used a plastic scraper and it took probably an hour. I cleaned up all of the old glue and the applied the replacement pad after making sure it was dry, it worked greatI remember you saying that previously, did you have any colour come off with it? I used some metho to clean some gunk off the inside of one door and it turned red, so I stopped? Makes me a bit nervous...... Link to comment Share on other sites More sharing options...
Ozvino Posted 20August, 2017 Report Share Posted 20August, 2017 I remember you saying that previously, did you have any colour come off wit it? I used soem metho to clean some gunk off the inside of one door and it turned red, so I stopped? Makes me a bit nervous......I was careful, main worry was it not leaking out of the bonnet area but it didn't, the quality of the tig welding they did on those aluminium bonnets is amazing. Zero colour came off, the padding soaked it up and then it scraped easily Link to comment Share on other sites More sharing options...
SteveF Posted 21August, 2017 Author Report Share Posted 21August, 2017 Thanks gents for your suggestions. I'll let you know how I go. Link to comment Share on other sites More sharing options...
